Can you convert LSI15 between left and right?
johnobuttons
johnobuttons Posts: 2
edited November 2013 in Speakers
Has anyone ever tried converting an LSI15 left speaker to a right speaker.
Seems like it might be possible.
John
Post edited by johnobuttons on
    EndersShadow Posts: 17,704
    Dont think so since the tweeter position is different between the two so you would need to re-drill the new position and fill in the old one.
    I would almost just call Polk and see if they have a cabinet they can sell you
    txcoastal1 Posts: 13,513
    I have never seen a cut away but the framing inside coming up to the dual ports would inhibit the relocation of the tweeter
    tonyb Posts: 33,072
    John
    Maybe some more info as to WHY someone would want to do that ? That would only be possible on mirrored pairs of speakers, not dedicated left and right.
  • HHStuart
    HHStuart Posts: 263
    Am I missing something here? There are big holes in the side that are on different sides for left and right. What do you do about those?
    Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
    Subwoofer - Epik Legend
    Receiver (as Preamp) - Sony STR-DA3400 ES
    Amplifier - Outlaw 7125
    Television - 58" Samsung Plasma PN58B860
    Blu Ray - OPPO BDP 83
    tonyb Posts: 33,072
    Your not missing anything, and your right. The Op asked...we answered. A mirrored pair of speakers, meaning identical to each other, is no problem switching left to right or visa-versa. Dedicated left and right speakers are built from the ground up that way, cabinets, placement of drivers. To try and change that would mean building a new speaker. Some have switched dedicated speakers so that side firing woofer throws to the inside rather than the out, which seems to work ok for some.
  • hochpt21
    hochpt21 Posts: 5,423
    HHStuart wrote: »
    I was thinking the same thing.
  • johnobuttons
    Thanks for the help. LSI15 left speakers are selling really cheap on ebay, but haven't seen right speakers.
    I haven't seen how the LSI15 is put together and had wondered if woofer portion could be turned 180 degrees so woofer would fire in.
    I can imagine how it would likely be impossible.
  • zingo
    zingo Posts: 11,258
    It would not be worth your time or money; it would be cheaper to buy a stereo pair.
