Too much wire, not enough room
apc
Need help behind my A/V receiver. It's on a slide out shelf and the shortest speaker wire (banana to banana) still had to be coiled. I have way too much wiring and wonder if shorter cables are made and if you have any ideas regarding this mess. Really only need about 2 ft speaker cables.
Husband, Father, Son, Brother, Friend.
Post edited by apc on
Have you considered making your own?Set up: 11.2 HT + 2ch
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
Just telling my wife that's what I'd get back as a response. Guess I'll have to.Husband, Father, Son, Brother, Friend. -
Helicopterpioletdoug is said to make excellent cables http://www.douglasconnection.com/
I can make you whatever length you need, or fix you up with what you need if you want to DIY. PM me if you need some help.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
Thank you. Will go to PM.Husband, Father, Son, Brother, Friend.
Monoprice will work but it's not the greatest choice to use IMHOSAMSUNG LCD--52", 240hz
Panamax 5300PM--Power Conditioner
CSIa6--Center Channel
RTIa3--Front High Channels
FXIa6-- Rear Channels
Sony--3-way Tower Speakers (20yrs old)
DSW pro 500--Subwoofer
PIONEER 1021-K--7.1 Reciever
My Own Custom Audioquest 14/4--Speaker Cables
Audioquest--Cinnamon HDMI Cables
Sony--PS3
eventually i will own the RTIa9's but for now im using20 year old sony 3way towers.:mad:
STILL NEED:
Pioneer Elite 7.1 Receiver with pre-outs
Emotiva XPA-3 Amplifier -
I would think that if you are only going 2 or so feet, that cable would be fine.
Monoprice cable is fine. I use similar OFC in-wall speaker cable in my HT and party systems, the latter up to 40 feet.Main System: Denon DP-59L | Audio-Technica AT33EV | Marantz SA-11S2 | Classe DR-10 | Classe CA-300 | Classe RC-1 | PSB Stratus Gold i's | DIY Balanced AC Power Conditioner | Acoustic Zen and NeoTech cables | Oyaide and Furutech power connectors | Dedicated 20A isolated ground line.
Party System: Laptop #2 | Audioquest Dragonfly USB DAC | Technics SU-A6 | Acurus A-250 | Radio Shack 15-band EQ | Pioneer SR-9 reverb | Cerwin Vega DX9's | Dayton 100° x 60° horns with titanium HF/MF compression drivers. -
I may not even do banana plugs in the re-do. I thought it looked neat, but turns out it is somewhat hard to reach back there to insert the plugs. Had it been an exposed area, it would've been a better idea. As it is, I'm talking myself into removing the plates and hard-wiring.
Thank you for your input so far. Ideas always appreciated.Husband, Father, Son, Brother, Friend. -
