Too much wire, not enough room
apc
apc Posts: 779
Need help behind my A/V receiver. It's on a slide out shelf and the shortest speaker wire (banana to banana) still had to be coiled. I have way too much wiring and wonder if shorter cables are made and if you have any ideas regarding this mess. Really only need about 2 ft speaker cables.
Husband, Father, Son, Brother, Friend.
Post edited by apc on
  • Geoff4rfc
    Geoff4rfc Posts: 2,968
    edited November 2013
    Have you considered making your own?
  • apc
    apc Posts: 779
    Geoff4rfc wrote: »
    Just telling my wife that's what I'd get back as a response. Guess I'll have to.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    Helicopterpioletdoug is said to make excellent cables http://www.douglasconnection.com/
  • helipilotdoug
    helipilotdoug Posts: 1,230
    I can make you whatever length you need, or fix you up with what you need if you want to DIY. PM me if you need some help.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • apc
    apc Posts: 779
    Thank you. Will go to PM.
  • apc
    apc Posts: 779
    Found some left over in-wall 14ga speaker wire. Wouldn't this be OK to use?
  • ft_townman
    ft_townman Posts: 30
    Monoprice will work but it's not the greatest choice to use IMHO
    SAMSUNG LCD--52", 240hz
    Panamax 5300PM--Power Conditioner
    CSIa6--Center Channel
    RTIa3--Front High Channels
    FXIa6-- Rear Channels
    Sony--3-way Tower Speakers (20yrs old)
    DSW pro 500--Subwoofer
    PIONEER 1021-K--7.1 Reciever
    My Own Custom Audioquest 14/4--Speaker Cables
    Audioquest--Cinnamon HDMI Cables
    Sony--PS3
    eventually i will own the RTIa9's but for now im using20 year old sony 3way towers.:mad:
    STILL NEED:
    Pioneer Elite 7.1 Receiver with pre-outs
    Emotiva XPA-3 Amplifier
  • Zeros
    Zeros Posts: 940
    I would think that if you are only going 2 or so feet, that cable would be fine.
  • Glen B
    Glen B Posts: 269
    Monoprice cable is fine. I use similar OFC in-wall speaker cable in my HT and party systems, the latter up to 40 feet.
  • apc
    apc Posts: 779
    I may not even do banana plugs in the re-do. I thought it looked neat, but turns out it is somewhat hard to reach back there to insert the plugs. Had it been an exposed area, it would've been a better idea. As it is, I'm talking myself into removing the plates and hard-wiring.
    Thank you for your input so far. Ideas always appreciated.
  • apc
    apc Posts: 779
    edited December 2013
    Took a few minutes today and built a prototype short speaker cable.
    40d47c00-db2c-4980-9c91-88e9105938c1_zpsb42204ee.jpg1c74055b-2d8d-43bb-9062-965d9924fe60_zpsa519a206.jpg
