TV stand for CSI A7?
Megazine
Megazine Posts: 8
edited November 2013 in Speakers
Hi, I'm pretty much new here & I recently bought a CSI A7 center speaker. My issue is that I need a new TV stand that can fit this speaker. I did research on the forums & didn't find an answer. Curious to know if anyone ever solved this dilemma. I will be putting a 65 inch plasma on top of stand as well with all my other components below. I pretty much surfed all over the web & came up expensive stands that might work. My budget is $300-$600. I also would love a stand that I can hide the wires. I'm hoping for some advice. Thanks!
Post edited by Megazine on
  • Geoff4rfc
    Geoff4rfc Posts: 2,839
    Congrats on your new center speaker. You do mean the CSiA6 though, right?
    With that kind of budget, have you considered a do it yourself (DIY) project? I had a much much smaller budget than that and was able to accomplish a useable stand for both plasma, center speaker and components. Of course, my original design included housing my sub which turned out to be a bad idea, but a quick change was fixable.
    This stand I've built has taken on 4 or 5 different changes, since I no longer needed it to support the TV, speaking of, if you can wall mount your plasma, that would be great, but if not, you can still come up with some useable designs.
    Here are some pics of what I was able to pull off with a little bit of lumber, some 2" dowels, wood screws, a drill, jig saw, some stain and clear finish;
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • Megazine
    Megazine Posts: 8
    Sorry I meant the CSiA6. That actually looks really good. I haven't considered that & I don't have the tools. If that's my only resort then I might have to look into it. I'm thinking of maybe ceiling mounting my 65" plasma because the only place I can position it would be in front of my living room window which is a shame because it blocks sunlight. A tv that size actually makes me nervous to have hanging from the ceiling but I heard it's safe if done right.
  • mufsoman
    mufsoman Posts: 636
    I would think twice about the ceiling mount just because of the high angle of viewing it would create. Unless you hang it low enough from the ceiling mount, but then your better off setting it on a cabinet or re-arranging to find a wall to mount to....
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime towers, center channel and bookshelfs (side surrounds)
    Atmos: Mirage Nanosats x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • Megazine
    Megazine Posts: 8
    Here is my living room layout. As you can see my only option for a great viewing & audio experience would be to place the TV in from of the window. Pretty much all I can do is build a cabinet which will be hard because of my schedule or ceiling mount it. TV is 65"
  • Megazine
    Megazine Posts: 8
    Looks like it will do the job. Wish it was a bit wider but it will work! Thanks everyone. Here is a picture if anyone comes into this situation. http://www.sonax.ca/Webpages/ProductInfo.asp?disp=cat&category=TV%20Stands%20and%20Benches&model=B-051-LMT
  • MADGSF
    MADGSF Posts: 603
    I have the CSiA5 which is the older model of the same speaker and is the same size. I went with a company call Standout Design, the model is Horizon XL. They are not cheap but are furniture grade quality and fit that center like it was made for it.
    www.standoutdesigns.com/collections/solid-wood-tv-consoles-tv-stands-media-consoles/products/horizon-n702-xl-solid-wood-tv-console
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • badchad
    badchad Posts: 348
    This is my stand/setup. One of the few stands that can hold a CSiA6 INSIDE of the cabinet.
    It's also one of the few that can hold larger receivers. I liked the fact it hid all my equipment. Helps on the WAF.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • polk500
    polk500 Posts: 1,171
    They are all great looking stands guys.
    And Badchad nice presentation looks really sharp.
    Cheers
    Roger
  • Megazine
    Megazine Posts: 8
    That stand ed very sexy. Definitely looks expensive. Which stand is it?
  • badchad
    badchad Posts: 348
    If you were asking about mine, it's a Plateau SR-V-75.
    It's big. You might guess (from the model number) it's 75" wide. The TV above it is a 70". My attempt was to somewhat stealthily hide my gear, and I had some problems housing both the CSiA6 and the Yamaha RX-A2010 receiver inside of a stand. At the time, I didn't really plan for the B&K amp, but that's how it goes and it fits in there well.
    It ran about $800. I replaced the frosted glass windows with tinted glass for another $50 or so at my local glass shop.
    It's my first stand so I don't have a lot to compare it to, but it's worked out well. My only complaints are that it is low to the ground. It's about 19" off the floor. I should probably move the center on top of the stand, but it kinda pains me to do so since I searched high and low for a stand that could house it. I'm not sure what I expected, but I kind think for the price, the build quality could be a bit better. Overall though it does the job.
    Polk Center: CSi A6
    B&K Reference 200.7
    Oppo BDP-103
  • Geoff4rfc
    Megazine wrote: »
    Good job!! Looks nice too! Hope it works out for you well enough!
    Set up:
