Anyone of you tube guys shed any light on this
pitdogg2
http://www.ebay.com/itm/141028718143?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Looking through 6AK5 tubes came across this one. Is it just a tube with a capacitor in it? If so why would they still chrome the top or whatever they do.
thanks
thanks
Post edited by pitdogg2 on
There are quite a few tubes that have a connection on the top. The 811A is an example, four pins on the bottom and a cap on the top.
Kenneth Swauger wrote: »There are quite a few tubes that have a connection on the top. The 811A is an example, four pins on the bottom and a cap on the top.
Yep I have seen those tubes that also connect at the top. Never knew that was the case with the EF95 6ak5 stuff. So it is safe to say it not a tube buffer tube
Wonder what they were used in?
thanks for the info Ken -
With a cap it should be connected to high voltage lead, never seen a tube with one and not connected to a wire.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
The 811A in the Altec 1570B has 935 Volts on the plate connection (the end cap).
As has been noted above :-) High voltage plates (e.g., in color TV high-voltage sections or linear RF amplifiers... or high-power AF triodes) operating at frighteningly high plate voltages, the top (or side) of envelope plate caps were often used.
In some early (mostly radio) tubes, the top connector might be for a grid instead of a plate. -
Kenneth Swauger wrote: »The 811A in the Altec 1570B has 935 Volts on the plate connection (the end cap).
935v will bite you
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
only once.
Twice if really stupid!
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
McAlister used 40KG6 horizontal output TV tubes in his amps once upon a time. I had one. A homely home built look but it sounded good.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Old TV horizontal output tubes Kooooolll I think a tube like that could output 20w or so.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »Old TV horizontal output tubes Kooooolll I think a tube like that could output 20w or so.
Lots more than that run in class AB push-pull (or push pull parallel); they were - and still are - widely used in RF linear amplifiers for amateur radio (not to mention outlaw CB "heaters") as a (relatively) cheap source of moderately high output power.
My favorite application of horizontal sweep tubes in audio is probably the McIntosh MC-3500 monoblock amplifier...
Eight 6LQ6 (6JE6) sweep tubes PPP for 350 watts :-)
As far as the plate caps go: If <touch>, then <die>.
http://www.roger-russell.com/amplif2.htm#mc3500 -
Nice and like the fan in the back also.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I suspect it needs the fan ;-)
SCompRacer wrote: »McAlister used 40KG6 horizontal output TV tubes in his amps once upon a time. I had one. A homely home built look but it sounded good.disneyjoe7 wrote: »Old TV horizontal output tubes Kooooolll I think a tube like that could output 20w or so.mhardy6647 wrote: »Lots more than that run in class AB push-pull (or push pull parallel); they were - and still are - widely used in RF linear amplifiers for amateur radio (not to mention outlaw CB "heaters") as a (relatively) cheap source of moderately high output power.
very very cool guys pleasing eyeball **** to say the least... -
I'm not generally a big fan of high power... but I've gotta admit that I would take a certain amount of perverse pride in owning a pair of those Mac MC-3500 monoblocks if the opportunity ever presented itself ;-)
mhardy6647 wrote: »I'm not generally a big fan of high power... but I've gotta admit that I would take a certain amount of perverse pride in owning a pair of those Mac MC-3500 monoblocks if the opportunity ever presented itself ;-)
you'd be a fool not to....well unless you're out of donatible body parts. -
You can have the same version of MC-3500 in industrialized version called MI-350 for nearly 20K. This is big time out of my league but I think if I need that much tube power, there are better and cheaper way these days.
http://www.ebay.com/itm/McIntosh-Mi350-mono-tube-amplifiers-/271328120765?pt=Vintage_Electronics_R2&hash=item3f2c6a8fbdTrying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
So who's driving to CAL?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
The only one who could afford all the gas Sal
