Replacing woofer on CS400 center channel.
gcccowboy
gcccowboy Posts: 2
Ordered a new woofer straight from polk (MW7018) after crackling in the right woofer. Installed it tonight and it doesnt seem like its producing any sound. The left woofer and the tweeter work but nothing from the new woofer. Any thoughts? The red wire is hooked on the side with the red dot.
Post edited by gcccowboy on
    F1nut Posts: 51,770
    edited November 2013
    The problem may not have been the woofer, it may be the crossover. A simple test, swap the left and right woofers.
  • gcccowboy
    gcccowboy Posts: 2
    Its just weird that the other one before i took it out was at least making sounds and was crackling too.
    F1nut Posts: 51,770
    Lots of weird things happen in this hobby. Swap them and report back.
  • WLDock
    WLDock Posts: 3,073
    Yes, test the woofers. i would pull out all three and test them one by one connected direct to the amp avr at low volume....this takes the crossover out of play. This way you can listen for noise from the motor. You should be able to better find the issue with the driver.
    If all three drivers turn out to be ok, then you will know that there is a problem with the crossover. If so, pull the crossover out and give it a visual inspection. Look for bad solder joints or charred componenets or traces on the circuit board.
