Is this correct
oldrocker
Quick question as I just got the connect cable for my SDA SRS's.
Is this the proper hookup for the connect cable, jumper wires and speaker wires in a 2 channel set up?
TKS
TKS
Post edited by oldrocker on
yes it isSDA SRS 2.3TL's
SDA 2B TL's -
Thanks Sir. I thought so but was not gonna take a chance!!
You need to step up to the late o the speaker cables for these to sound their best.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
yes it looks correct, but check the positive is red and the negative is black
What is that slimy looking stuff on that binding post plate?
The red (+) binding posts should be on the left, black (-) on the right.
You seriously need some high quality speaker cable and jumpers.Political Correctness'.........defined
President of Club Polk -
Is there a source for the interconnect cables? Also what do you guys recommend in speaker cable?HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
Call Polk for the IC cables, and recommendations for speaker cables covers more pages on this forum than the Bible; do a search.
Highly recommend Douglas Connection, Signal or Blue Jeans Cables as good starting points. Both Frank @ Signal and Doug @ DouglasConnection give Club Polk members a discount.
I suggest going with bi-wire speaker cables."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
