Is this correct
oldrocker
oldrocker Posts: 2,590
Quick question as I just got the connect cable for my SDA SRS's.
Is this the proper hookup for the connect cable, jumper wires and speaker wires in a 2 channel set up?
TKS
Post edited by oldrocker on
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited October 2013
    yes it is
    SDA SRS 2.3TL's
    SDA 2B TL's
  • oldrocker
    edited October 2013
    Thanks Sir. I thought so but was not gonna take a chance!!
    nooshinjohn Posts: 25,969
    edited October 2013
    You need to step up to the late o the speaker cables for these to sound their best.
  • Narikisas
    Narikisas Posts: 9
    edited November 2013
    yes it looks correct, but check the positive is red and the negative is black
    F1nut Posts: 51,915
    What is that slimy looking stuff on that binding post plate?
    The red (+) binding posts should be on the left, black (-) on the right.
    You seriously need some high quality speaker cable and jumpers.
  • xjghost
    xjghost Posts: 1,115
    Is there a source for the interconnect cables? Also what do you guys recommend in speaker cable?
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • zingo
    zingo Posts: 11,258
    Call Polk for the IC cables, and recommendations for speaker cables covers more pages on this forum than the Bible; do a search.
    EndersShadow Posts: 17,715
    Highly recommend Douglas Connection, Signal or Blue Jeans Cables as good starting points. Both Frank @ Signal and Doug @ DouglasConnection give Club Polk members a discount.
    I suggest going with bi-wire speaker cables.
