Psw 125
seabass
seabass Posts: 1
edited November 2013 in Troubleshooting
Hello, I have a PSW 125 and my built in amp fried. Every time I try to change the fuse it just blows. I removed the amp from the case and I notice a small transistor. Broke in half. I went to, local electronics shops and no one seems to be able to fix it.… my question is… does anybody know where I can buy a replacement???
Post edited by seabass on
    txcoastal1 Posts: 13,505
    The bands are color codes for value, can you post a pic. It's usally really a no brainer to replace can you post a couple of pics
