Separate Subs for 2-Channel System
kevhed72
POLL for the Forum: Is it WORTH THE EFFORT to run dedicated power lines / outlets for 2 (two) subwoofers in a dedicated 2-channel system (assuming room will be built from 'scratch')?
A. YES
B. NO
C. Split the difference and run BOTH subs off one dedicated circuit
A. YES
B. NO
Post edited by kevhed72 on
Since you're building the room from scratch then most definitely run the separate line for the subs & dedicated lines for the main system also. Do it all now while the room is easy to make all the runs.
If it were me, I would run 4 dedicated, 20 amp capable outlets. You can always put a 15 amp outlet in a 20 amp circuit. Mono/stereo/multichannel amps on one or 2 outlets, one or 2 subs on one outlet, and conditioner/rest of rig on fourth.
+1. imo2Ch Tube Audio Convert -
There's no need for the 15A outlet, as the 20A outlet will also accommodate NEMA 5-15 plugs.If it were me, I would run 4 dedicated, 20 amp capable outlets. You can always put a 15 amp outlet in a 20 amp circuit.Main System: Denon DP-59L | Audio-Technica AT33EV | Marantz SA-11S2 | Classe DR-10 | Classe CA-300 | Classe RC-1 | PSB Stratus Gold i's | DIY Balanced AC Power Conditioner | Acoustic Zen and NeoTech cables | Oyaide and Furutech power connectors | Dedicated 20A isolated ground line.
Party System: Laptop #2 | Audioquest Dragonfly USB DAC | Technics SU-A6 | Acurus A-250 | Radio Shack 15-band EQ | Pioneer SR-9 reverb | Cerwin Vega DX9's | Dayton 100° x 60° horns with titanium HF/MF compression drivers. -
My thought now is to run 3 dedicated circuits:
1. Integrated amp
2. 2 subs to go with 703 bookshelves
3. Power conditioner for everything else
I am contemplating upgrading the service panel myself, but we'll see.... -
I would probably run 1 30amp ckt, as I have never had an issue with a single 15amp ckt, even back in the days of running 600watts/rms (1200 watts peak!) w/bridged amps.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Please clarify....ckt(?) -
CKT= circuit
Hello, kevhed72 and good afternoon to you. You may find this discussion of some interest since you are building from scratch. http://www.whatsbestforum.com/showthread.php?9426-Dedicated-lines-and-properly-integrated-grounding-A-discussion
Now with that said..."is it worth the effort?" Well, I will put it to you like this. I read this somewhere recently and the analogy simply makes sense to me.....[this is not word for word but roll with it, if you will].....
Dedicated lines you may want to consider something like that of a boat. Consider one dedicated line as one 75Hp outboard motor on a boat. Consider adding another dedicated line as adding another 75Hp outboard motor. Sure the first motor will get you going and it will get you there but when going against headwinds and current, that second motor will sure help you along the way.
I am a strong advocate of proper power, as I have heard what it can do for a system. Especially a system that stands out amongst the others.
I'm not sure about a 30 Amp circuit, as you can't incorporate 15 or 20 Amp receptacle's into it.
For those doing big multi-circuit rooms. Run just one high current line from the main breaker box to a central point in the room. Then into a small breaker box to the individual circuits. The idea being to reduce the length of the runs from component to component. -
Well, here's a follow up question on this whole idea - since my breaker box is currently full (ie no open circuits to use), how many of you would attempt to replace your current box with a higher-capacity one. I spoke to someone who installs HVAC and was told I need to measure the told AMPS being pulled by all the existing circuits to see if upgrading the box was possible.
Thoughts....has anyone attempted this themselves? -
Now, that is a very dangerous idea! With no fuses on the other side of the breaker box, a mistake and you could have 10,000 Amps at 240 Volts to deal with. And no, the HVAC guy doesn't know anything about it either.
Have you thought of a sub panel relatively easy to install and cheaper then pulling apart your existing main panel. and then as speedskater suggested a small panel in a central panel in your media room.
I would figure our what your total power demand is. Remember when you start pulling dedicated circuits ground is referenced at the wall outlet and that means a higher potential of ground loop hum with multiple outlets. You may be causing more problems then fixing any perceived deficiency.
Consider pulling a single 20 AMP circuit, save the money from the other pulled lines and instead get a +60/0/-60 balanced power supply for everything except the amps.
Another useful poll is to see how many people trip their 20AMP service on a regular basis. You could install a Kill-a-watt and see what your power draw actually is. -
When it comes to stuff that is either a) very technical or b) can kill you if you screw up... I call in a pro. That said Disneyjoe7, and maybe Serendipity IIRC did some electrical mod's to his house not too long ago, so shoot him a PM. All that said (see below)Have you thought of a sub panel relatively easy to install and cheaper then pulling apart your existing main panel. and then as speedskater suggested a small panel in a central panel in your media room.
I would think this would be a better option for you and possibly cheaper. Doing this you could get all your HT items on one box totally independent of any of the other ones."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
And here we go:
http://www.polkaudio.com/forums/showthread.php?120229-Upgrading-Electrical-Service-anyone-DIY
And
http://www.polkaudio.com/forums/showthread.php?102110-My-work-in-progress..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
OK, so here is the deal on upgrading your main breaker box (panel board). What you really need is more circuit breakers, most people don't need higher amperage (but higher amp boxes don't cost much more. The limiting factor is how much the power company service to your house is rated for.
As to how much you need for the room's audio system. Everything with the exceptions of big power amps and video projectors should be wired to one 20 Amp breaker. You can check the big equipment's label or fuse for it's max current.
So if you have someone that can let the electrician into the house during the day, check at the small local shops or maybe someone at church does side jobs. So offer him a low priority job, that he can do if his planned job gets canceled or delayed. Offer to pay him in cash and to pay for the parts when they are delivered to your house. -
The only way to use a true 30A circuit is with an L5-30 (locking type) plug. You really only find those used on pro power distros. IMHO, a true 30A circuit (30A breaker/10AWG wire/30A receptacle) is not necessary except for a small number of rare very high powered amps or on a power distro supplying several pieces of equipment. Unless you have a pure class A amp drawing more than 16 amps continuous, a 20A circuit will work just fine.Speedskater wrote: »I'm not sure about a 30 Amp circuit, as you can't incorporate 15 or 20 Amp receptacle's into it.Main System: Denon DP-59L | Audio-Technica AT33EV | Marantz SA-11S2 | Classe DR-10 | Classe CA-300 | Classe RC-1 | PSB Stratus Gold i's | DIY Balanced AC Power Conditioner | Acoustic Zen and NeoTech cables | Oyaide and Furutech power connectors | Dedicated 20A isolated ground line.
It may not be necessary to replace your panel. You maye be able to get away with the addition of a subpanel to gain a few additional breaker spaces. You need to have an electrician calculate your demand load and advise you accordingly. The appropriate panel size is based on total SF of residential space and demand load.Well, here's a follow up question on this whole idea - since my breaker box is currently full (ie no open circuits to use), how many of you would attempt to replace your current box with a higher-capacity one. I spoke to someone who installs HVAC and was told I need to measure the told AMPS being pulled by all the existing circuits to see if upgrading the box was possible.
Thoughts....has anyone attempted this themselves?Main System: Denon DP-59L | Audio-Technica AT33EV | Marantz SA-11S2 | Classe DR-10 | Classe CA-300 | Classe RC-1 | PSB Stratus Gold i's | DIY Balanced AC Power Conditioner | Acoustic Zen and NeoTech cables | Oyaide and Furutech power connectors | Dedicated 20A isolated ground line.
