Looking to upgrade my digital interconnect
gmcman
gmcman Posts: 1,841
edited November 2013 in 2 Channel Audio
I have a couple older AQ Toslink cables, Optilink 1 and Optilink X. I am currently using a generic digital coax and I was looking at possibly going with a DH labs Silver Sonic DH-750 digital coax. http://www.silversonic.com/docs/products/D750.html
I read through a few threads and found that you don't need to spend a lot of coin on these and even possibly going with a BJC interconnect, I have a few of the LC-1 cables and like them a lot.
I'm after a 1 meter cable and I want to keep it as neutral as possible. I think what I have is slightly on the bright side but not overly so. I'm trying to get slightly more punch in the midrange if I had to briefly describe it.
Not sure which digital coax I have but it's all black with a single orange ring around the RCA. I thought Dayton originally but I honestly don't remember where I picked it up from.
Basically I want the best I can get without spending more than $150, and honestly finding one for $30 would be much more welcomed.
Post edited by gmcman on
  • steveinaz
    steveinaz Posts: 19,545
    FWIW, I own the DHLabs D-75, but (slightly) prefer my $24 Belden 1694A from Blue Jeans cable. Just saying.
    If you go BJC...go with a PROPER digital coaxial, not an analog IC. Just some friendly advice. The 1694A really blew me away when I got it---I thought I would hate it. I was wrong.
    EndersShadow Posts: 17,687
    I bought a black cat veloce off the forum for like 40 or 50 bucks. Best cable I own.
    Can do rca or bnc. Highly recommended.
    tonyb Posts: 33,068
    Don't be fooled, there are plenty of differences in digital cables. Maybe not as profound as regular analog cables, but certainly audible. The Blackcat mentioned above is a stellar performer. I'm using an Audio Metallurgy GA-0 digital cable that I simply won't part with, but that's probably more than your looking to spend.
  • gmcman
    gmcman Posts: 1,841
    steveinaz wrote: »
    What stands out with the BJC that gives it the slight edge? For the price it's a no-brainer just to have it and I have read many positive reviews.
  • zingo
    zingo Posts: 11,258
    The DH750 is a very good cable, and DH Labs true 75 ohm RCA plugs are some of the best.
  • steveinaz
    gmcman wrote: »
    I think it is a touch more neutral, especially in the midrange. The DH Labs is good too, no doubt. I bought the DH Labs a long time ago, and later tried the belden 1694A; I have felt no need to "upgrade" the 1694A--it's specs for 75ohm digital transmission are outstanding.
  • gmcman
    gmcman Posts: 1,841
    I have 1M of BJ 1694A on the way. Maybe around xmas if some loot rolls in (yeah right) I may try the DH 750 and compare. Anyone know if they changed the DH 75 much for the new 750, sonically anyway?
  • steveinaz
    gmcman wrote: »
    If you don't like the belden, send it to me, and I'll send you a 1M D-75 from DH Labs, RCA-RCA. How's that sound?
    IMHO, the 1694A is a "best kept secret" in digital cables.
    pitdogg2 Posts: 26,958
    steveinaz wrote: »
    I concur I have used it(1694A) to make analog cables as well as Canare L-5cfw personally I could not tell the difference.
  • gmcman
    gmcman Posts: 1,841
    steveinaz wrote: »
    I appreciate that offer......sure sounds like the 1694 is the winner. :) I will let you know.
    I was using the BJ LC-1 for my pre-amp interconnect, 1.5M and while slightly long it sounded real good. I moved the components around to try the .5M Kimber hero I have owned for about 8-10 years. The LC-1 seems tighter but the highs are more detailed with the Hero, but only slightly. I tried them back to back to back many times over the course of an hour and the LC-1 is 90-95% of the Hero.
    That's another interconnect I want to play with and not sure where to look but the Hero does very well.
