New basement setup
polk500
So after a few months last winter finally the basement is finished. And for anyone who's done this you know how much work it is.
Now we haven't got it decorated to my wife's taste quite yet,I made some panels for wall treatments but we haven't come to an agreement about what fabric to use. So some where down the road I may or may not install them.
Now all the walls and ceiling are insulated; outside walls pink insulation inside walls rock wool same as the ceiling.
Also the doors to the washroom and furnace room are call safe and sound basically solid core doors. It does keep the noise of the furnace to a minimum.
I must say the system sounds good.
My equipment is in a small closet to the right. I think I like the clean look as we get more furnishing set I will probably like it more.
Oh the room is 15 x 14 x 9' foot ceiling.
Sorry for the messed up attachments just figure out this afternoon how to upload from my Ipad
Cheers
Roger
Post edited by polk500 on
How is your center mounted?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Looks really nice. I've done some of that basement remodeling and I know how much work it is.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
I used two L brackets made from 1/4 inch x 1inch steel spray bombed black mounted upside down. The speaker sit up foam tape and the wall behind the TV is 1/2 plywood so it soildly mounted. Of course that's a little extreme but the TV weights 165 LB.
I would have no problem useing butterfly anchors in drywall if I couldn't catch a stud to screw into.
Cheers
Roger -
Looks very nice. Love the tv size & position where its at & cc. Now the question is how can you ride the horse & use the telescope & zoom in on your neighbors. You are good
Good job Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Nice work. It's gotta feel good to know you did all that work.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
boston1450 wrote: »looks very nice. Love the tv size & position where its at & cc. Now the question is how can you ride the horse & use the telescope & zoom in on your neighbors. You are good
Good job
lol!2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Thanks guys, and as for riding on the horse and using the telescope the same time. That would be a recipe for disaster for sure. And my neighbors are all ugly anyway wouldn't take a chance magnify them the lens might crack.
Cheers
Roger -
Thanks I abused then pretty bad a while ago but Trey fixed them up good. They sure sound sweet now.
Cheers
Roger -
Nice hardwood floors! Is it ash?
Imperial Walnut by Trillium it's an enginneer hardwood click flooring very nice to work with about 5/8 of an inch x 3.5 wide. I couldn't use plank flooring because the floor was below grade.
Cheers
Roger -
Some more pictures of the Reno, this bathroom almost drove me over the edge as I'm not a plumping or electrician. Lots of reading,pulled permits of course can't take any chances of making any mistakes.
Biggest thing in the wiring was fishing the wire over to the panel and installing the breakers a 220 gfi 30 amp and a 110 gfi 20 amp For the steam shower.
Think it came out well. Always wanted a separated water closet now I got one.
Cheers
Roger -
Looks nice man, maybe toe those speaks in a tad. Enjoy.HT SYSTEM-
lsi 9's -
Thanks Tony,
Being doing lots of experimenting with placement.
So currently they are 8" from the wall toe in 1/2" not sure what the degree would be that would require me to think to much tonight.
But because you mention it I suspect it not enough so I will toe in more and see how it sounds.
Thanks for the input.
Cheers
Roger -
Nice Room..........Is that a 65in Pany S1 TV?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
It's a VT30 65" best TV I've owned, I've had it just about two years and still amazed at the picture.
Cheers
Roger
