New basement setup
polk500
polk500 Posts: 1,171
edited November 2013 in The Clubhouse
So after a few months last winter finally the basement is finished. And for anyone who's done this you know how much work it is.
Now we haven't got it decorated to my wife's taste quite yet,I made some panels for wall treatments but we haven't come to an agreement about what fabric to use. So some where down the road I may or may not install them.
Now all the walls and ceiling are insulated; outside walls pink insulation inside walls rock wool same as the ceiling.
Also the doors to the washroom and furnace room are call safe and sound basically solid core doors. It does keep the noise of the furnace to a minimum.
I must say the system sounds good.
My equipment is in a small closet to the right. I think I like the clean look as we get more furnishing set I will probably like it more.
Oh the room is 15 x 14 x 9' foot ceiling.
Sorry for the messed up attachments just figure out this afternoon how to upload from my Ipad
Cheers
Roger
Post edited by polk500 on
  • Nightfall
    Nightfall Posts: 10,083
    How is your center mounted?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • zane77
    zane77 Posts: 1,696
    Looks really nice. I've done some of that basement remodeling and I know how much work it is.
    Two Channel
  • polk500
    Nightfall wrote: »
    I used two L brackets made from 1/4 inch x 1inch steel spray bombed black mounted upside down. The speaker sit up foam tape and the wall behind the TV is 1/2 plywood so it soildly mounted. Of course that's a little extreme but the TV weights 165 LB.
    I would have no problem useing butterfly anchors in drywall if I couldn't catch a stud to screw into.
    Cheers
    Roger
  • boston1450
    boston1450 Posts: 7,758
    Looks very nice. Love the tv size & position where its at & cc. Now the question is how can you ride the horse & use the telescope & zoom in on your neighbors. You are good :smile: Good job
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • hochpt21
    hochpt21 Posts: 5,423
    Nice work. It's gotta feel good to know you did all that work.
  • hochpt21
    boston1450 wrote: »
    looks very nice. Love the tv size & position where its at & cc. Now the question is how can you ride the horse & use the telescope & zoom in on your neighbors. You are good :smile: Good job
    lol!
  • polk500
    Thanks guys, and as for riding on the horse and using the telescope the same time. That would be a recipe for disaster for sure. And my neighbors are all ugly anyway wouldn't take a chance magnify them the lens might crack.
    Cheers
    Roger
  • polk500
    Thanks I abused then pretty bad a while ago but Trey fixed them up good. They sure sound sweet now.
    Cheers
    Roger
  • Hermitism
    Hermitism Posts: 4,337
    Nice hardwood floors! Is it ash?
  • polk500
    Imperial Walnut by Trillium it's an enginneer hardwood click flooring very nice to work with about 5/8 of an inch x 3.5 wide. I couldn't use plank flooring because the floor was below grade.
    Cheers
    Roger
  • polk500
    Some more pictures of the Reno, this bathroom almost drove me over the edge as I'm not a plumping or electrician. Lots of reading,pulled permits of course can't take any chances of making any mistakes.
    Biggest thing in the wiring was fishing the wire over to the panel and installing the breakers a 220 gfi 30 amp and a 110 gfi 20 amp For the steam shower.
    Think it came out well. Always wanted a separated water closet now I got one.
    Cheers
    Roger
    Looks nice man, maybe toe those speaks in a tad. Enjoy.
  • polk500
    Thanks Tony,
    Being doing lots of experimenting with placement.
    So currently they are 8" from the wall toe in 1/2" not sure what the degree would be that would require me to think to much tonight.
    But because you mention it I suspect it not enough so I will toe in more and see how it sounds.
    Thanks for the input.
    Cheers
    Roger
  • danz1906
    danz1906 Posts: 5,144
    Nice Room..........Is that a 65in Pany S1 TV?
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • polk500
    It's a VT30 65" best TV I've owned, I've had it just about two years and still amazed at the picture.
    Cheers
    Roger
