Cant get my wireless router to work with the new computer?
polkfarmboy
polkfarmboy Posts: 5,703
edited November 2013 in Electronics
My laptop died and on it was the wep? key I created to use the modem withAny general tips on how to get it to work with the new computer?
Its a netgear n600
Post edited by polkfarmboy on
  • gmcman
    gmcman Posts: 1,839
    I believe if you reset the modem via the small reset button (usually recessed) you can use the WEP key on the modem again.
  • zane77
    zane77 Posts: 1,696
    There should be a reset button on the back or bottom, after the router is powered all the way up hold this button in for 20 to 30 seconds this should restore the router to factory defaults and allow you to run the setup wizard to reconfigure the router. You will need to have your PC hard wired to the router to run this. The login is admin and the password is password this is all in lower case. Hope this helps.
    Two Channel
  • Jhayman
    Jhayman Posts: 1,548
    Ask your Porsche to help..
    Kidding what zane77 said should work..
  • polkfarmboy
    Ok it worked!!!! Thanks guys, there was no setup wizard and now I wonder how do I get to that and make a better more secure connection?
  • zane77
    zane77 Posts: 1,696
    The router IP address is 192.168.1.1, hook up your computer with an Ethernet cable and open your internet browser and use this address to access the router. The login and password are the same as I stated above admin and password. This should give you access to the setup page. Or you can be like me and live in the middle of nowhere and not worry about security because my nearest neighbor is three and a half miles away. And I'm three hundred yards to the road. So I don't worry about anyone using my connection.
    Two Channel
  • nguyendot
    nguyendot Posts: 3,594
    Default ip actually is 192.168.0.1 on netgear
    Main Surround -
  • drummer86
    drummer86 Posts: 441
    You can also navigate to routerlogin.net and that will bring you to the login screen as well. Easy to remember.
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
  • GospelTruth
    GospelTruth Posts: 403
    I know you had WEP security before, but it is highly recommended that you use WPA-2 Personal as that is latest standard for wireless security. WEP security can be broken by hackers in your neighborhood and it is the earliest form of wireless security. Once you change the security type, you will need to login to all your wireless devices and reconnect using the new security scheme and connection passcode. You will need to make sure though that all your other wireless devices can handle WPA-2. Anything built after 2006 should be able to. If you have older devices, it would be recommended to use WPA over WEP.
    I also change the default SSID so that it's more meaningful to me and family when they come visit and want internet access for their devices. It helps when you are in a crowded subdivision and everyone has a router broadcasting around you. But if you live on 40 acres, probably not needed. You can change all the above per the manual on pages 24-25.
    ftp://downloads.netgear.com/files/WNDR3300v2_SM_25MAR2010.pdf
    Michael
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
  • halo71
    halo71 Posts: 4,628
    zane77 wrote: »
    hehe....same here! I see more deer, coyote etc than people around here.
    --Gary--
