Any rice cooker fans here? Need recommendations...
starkiller
Looking for a small, under 6 cup, rice cooker that does really well with brown rice. We already have a cooker but my wife prefers white rice and i prefer brown so would like my own personal one
The cheaper the better of course...the Japanese ones would be really nice but way out of my price range
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
I would keep your eye out at Goodwill.
I have both sizes of the Cuisinart's and realy like 4 cupper
seems pretty fast and easy to use.
http://www.cuisinart.com/products/slow_cookers_rice_cookers/crc-400.html -
Rice cooker ?
Laz drives one doesn't he ?HT SYSTEM-
lsi 9's -
Zojirushi NP-HBC10 5.5 cup and never look back. It is induction heating (most like even better than the fuzzy logic).
http://www.zojirushi.com/ourproducts/how_and_chart/comparison_pdf/Zojirushi%20Rice%20Cooker%20Chart.pdf
Perfect brown rice even GABBA if you are in to that, excellent steel cut oats on the porridge setting.
http://www.zojirushi.com/user/scripts/user/prod_recipe_list.php?prod_category_id=1
Expensive, but we use this 4 or 5 times a week. Amazing machine. Picked mine up a Kohls when they do their 30% off coupon deal; sometimes Amazon matchs or has an even lower price.SDA SRS 1.2
Adcom GFA-5802
Adcom GFP-750
Sony DVP-NS999ES -
Very nice but way too expensive for us
Just need something for me, i know you get what you pay for but....
will have to watch the thrifts around here i guess...Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
Hey man.
My wife's from Indonesia and she knows her rice cookers inside and out.
Still using the one her mom gave her 15 years ago.
Cooks brown rice great.
Her advice - Get one from an Asian grocery.
PM me with your e-mail address for more details/discussion.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
http://Vimeo.com/channels/stretchphoto -
Will do, there are lots of asian grocery stores to pick from here in Seattle
We have only bought the cheap ones. $25.00 - $35.00 range. Make sure pan is non stick.MIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
starkiller wrote: »will have to watch the thrifts around here i guess...
Understand.....from your signature block one can see you know your priorities
SDA SRS 1.2
Adcom GFA-5802
Adcom GFP-750
Sony DVP-NS999ES -
I eat rice everyday. It is my primary food source. I would also recommend Zojirushi or Tiger, do some shopping around and you should find one for a good price. With your preference of under 6 cups, the price should be even less.
The problem with low priced cookers is the uneven heat and the ability to keep the rice warm. The rice will burn at the bottom and will also spoil within 24 hours (depending on season). Now, you could still buy the lower priced cookers (under $60), just make sure to unplug it once the rice is cooked. Store in fridge what is left over.
You could also get buy with an Emiril by TFal. Cooks very well, and does not burn the rice. It will slightly dry out the rice over extended periods, like over two days.
Good luck on your search.
Edit: you could also always register an email address with bedbathandbeyond.com and receive a lot of 20% off coupons to use.
Halen -
What Halen said, Zojirushi or Tiger. Don't skim, or you'll be ending up buying another one w/in 4-6 months.
Yeah, Tiger and Zojirushi would seem to be the way to go...Bed Bath and Beyond had a total of 3 models to see in their store
Will have to check online i guess... Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
When I want to cook rice, I use AT&T. Even comes with a side of sweet and sour pork and crab ragoons.HT SYSTEM-
lsi 9's -
Decided to go cheap to start out so bought a small Aroma unit that has a brown rice setting and a bag of Lundberg rice..gonna start steaming today..if all goes well will try out a bag of the recommended Sukoyaka Genmai rice.Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Zojirushi
For Tony B...that's a rice burner, not a rice cooker.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
