Looking for pre-amp suggestions
igottrades
I knew that somehow this would happen.
I collected all the pieces for my setup (see my sig), but currently every now and then my Denon just shuts off with a blinking red light. Typically this happens when I play Skyrim and there is a heated fight with tons of sounds going on. I am assuming it's just not able to juice the speakers properly, so it would seem I need a pre-amp?
If that's the case, could anyone suggest one they are using, especially with the Denon AVR-E300 that I own. What things should I look for that are key in a pre-amp? I am also not looking to spend a fortune, but a high quality signal/sound are always good to have.
Thank you ahead of time.
Denon AVR-E300 5.1, RT1000p, F/X500i, CS400i, Vizio 60" LED 120Hz
Post edited by igottrades on
You don't need a pre-amp, you need a regular amp. Your problem is your receiver is entry level and has no pre-outs to even add an amplifier. Kill 2 birds with one stone and find a used Pioneer elite SC series receiver.HT SYSTEM-
lsi 9's -
^ what Tonyb said..ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables
Yes, your Denon is running out of power and going into protection. A more powerful receiver that includes preouts for all channels will allow you the flexibility of adding an external amp in the future.Main System: Denon DP-59L | Audio-Technica AT33EV | Marantz SA-11S2 | Classe DR-10 | Classe CA-300 | Classe RC-1 | PSB Stratus Gold i's | DIY Balanced AC Power Conditioner | Acoustic Zen and NeoTech cables | Oyaide and Furutech power connectors | Dedicated 20A isolated ground line.
Party System: Laptop #2 | Audioquest Dragonfly USB DAC | Technics SU-A6 | Acurus A-250 | Radio Shack 15-band EQ | Pioneer SR-9 reverb | Cerwin Vega DX9's | Dayton 100° x 60° horns with titanium HF/MF compression drivers. -
Damn! Looks, I'll have to upgrade then. Thank you!Denon AVR-E300 5.1, RT1000p, F/X500i, CS400i, Vizio 60" LED 120Hz
