Kindly suggest amp or amps for the setup below.URGENT
dheep4225
Hello,
I'm looking to get advice on what the best amp or amps would be for the setup below in my Honda Brio Hatchback.
Sony XAV 64BT DVD/CD/USB Receiver
Polk Audio DB 6501 in front.
Polk Audio DB 691 in the rear.
Polk Audio MM1240 SVC 12'' Single Voice Coil Subwoofer.
I'm into classic rock, death metal and hard rock... So I'm looking for sound quality with punchy, accurate, and clear bass, mids, and highs. I don't listen ridiculously loud most of the time, but I would like that capability... and I definitely want clean sound.
Can I use Polk Audio DB 6501 both in front and rear?
Thank You.
Thank You.
Post edited by dheep4225 on
Maybe one or two more threads will get you your answer quicker.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Thank U...:-)
Polk PA4000.4 for the speakers.
http://www.polkaudio.com/products/pad4000_4
And the 2000.2 for the sub wired mono.
http://www.polkaudio.com/products/pad2000_2polkaudio sound quality competitor since 2005
Thank U, MacLeod...I need one more suggestion...(sorry for the trouble)
I'm looking to get advice on what the best amp or amps would be for the setup below in my Ford Figo Hatchback.
Sony XAV 601BT DVD/CD/USB Receiver
Polk Audio MM6501 in the front.
Polk Audio MM691 in the rear. (Can I use Polk Audio MM6501 both in front and rear?)
Polk Audio DB1212 12'' Subwoofer Enclosure.
Thank You. -
Same 4 channel but that DB is a 2 ohm sub so youd need a 2 ohm stable mono amp so the PA D1000.1.
http://www.polkaudio.com/products/pad1000_1polkaudio sound quality competitor since 2005
Thank U, Macleod. Three more questions. Expecting your help and knowledge.
1. Can I use Polk Audio MM6501 both in the front and rear? [for my Ford Figo hatchback]
2. Can I use Polk Audio DB 6501 both in the front and rear? [for my Honda Brio hatchback]
3. Polk Audio MM1240 SVC 12'' Single Voice Coil Subwoofer or Polk Audio DB1212 12'' Subwoofer Enclosure? (Which is better for a hatchback?) -
Polk Audio MM1240 SVC 12'' Single Voice Coil Subwoofer or Polk Audio DB1212 12'' Subwoofer Enclosure- Which is best?
Don't know. Check the fitment guide.2. Can I use Polk Audio DB 6501 both in the front and rear? [for my Honda Brio hatchback]
See #13. Polk Audio MM1240 SVC 12'' Single Voice Coil Subwoofer or Polk Audio DB1212 12'' Subwoofer Enclosure? (Which is better for a hatchback?)
The MM is a better sub than the DB.polkaudio sound quality competitor since 2005
