Kindly suggest amp or amps for the setup below.URGENT
dheep4225
dheep4225 Posts: 6
edited November 2013 in Car Audio & Electronics
Hello,
I'm looking to get advice on what the best amp or amps would be for the setup below in my Honda Brio Hatchback.
Sony XAV 64BT DVD/CD/USB Receiver
Polk Audio DB 6501 in front.
Polk Audio DB 691 in the rear.
Polk Audio MM1240 SVC 12'' Single Voice Coil Subwoofer.
I'm into classic rock, death metal and hard rock... So I'm looking for sound quality with punchy, accurate, and clear bass, mids, and highs. I don't listen ridiculously loud most of the time, but I would like that capability... and I definitely want clean sound.
Can I use Polk Audio DB 6501 both in front and rear?
Thank You.
Post edited by dheep4225 on
  • Nightfall
    Nightfall Posts: 10,083
    Maybe one or two more threads will get you your answer quicker.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • dheep4225
    dheep4225 Posts: 6
  • MacLeod
    MacLeod Posts: 14,358
    Polk PA4000.4 for the speakers.
    http://www.polkaudio.com/products/pad4000_4
    And the 2000.2 for the sub wired mono.
    http://www.polkaudio.com/products/pad2000_2
  • dheep4225
    dheep4225 Posts: 6
    Thank U, MacLeod...I need one more suggestion...(sorry for the trouble)
    I'm looking to get advice on what the best amp or amps would be for the setup below in my Ford Figo Hatchback.
    Sony XAV 601BT DVD/CD/USB Receiver
    Polk Audio MM6501 in the front.
    Polk Audio MM691 in the rear. (Can I use Polk Audio MM6501 both in front and rear?)
    Polk Audio DB1212 12'' Subwoofer Enclosure.
    Thank You.
  • MacLeod
    Same 4 channel but that DB is a 2 ohm sub so youd need a 2 ohm stable mono amp so the PA D1000.1.
    http://www.polkaudio.com/products/pad1000_1
  • dheep4225
    dheep4225 Posts: 6
    Thank U, Macleod. Three more questions. Expecting your help and knowledge.
    1. Can I use Polk Audio MM6501 both in the front and rear? [for my Ford Figo hatchback]
    2. Can I use Polk Audio DB 6501 both in the front and rear? [for my Honda Brio hatchback]
    3. Polk Audio MM1240 SVC 12'' Single Voice Coil Subwoofer or Polk Audio DB1212 12'' Subwoofer Enclosure? (Which is better for a hatchback?)
  • dheep4225
    dheep4225 Posts: 6
    Polk Audio MM1240 SVC 12'' Single Voice Coil Subwoofer or Polk Audio DB1212 12'' Subwoofer Enclosure- Which is best?
  • MacLeod
    dheep4225 wrote: »
    Don't know. Check the fitment guide.
    See #1
    The MM is a better sub than the DB.
