Dedicated amp & AVR setup advice wanted
Jestered
Jestered Posts: 49
edited October 2013 in Electronics
Hi all. So it looks like I'll be getting an Emotiva LPA-1 7 channel amp here soon. So that has me wondering exactly how I should set this up with my Pioneer Elite receiver. There's pretty much only 3 scenarios I can think of which include:
1. Run all the speakers through the amp. The amp is a 125WPC amp for 5 channels and 50WPC on the remaining 2 channels (when the amp is using all 7 channels). With my setup (in my signature) I would likely have my two side surrounds (the Polk RT15I's) on the lesser 50WPC channels.
2. Use the amp with only 5 channels. This would produce about 140WPC on all channels from the amp. The amp would power the front stage and my rear surrounds (the FXiA4's). That would leave the side surrounds being powered by the Pioneer Elite AVR, which should be around 136WPC there.
3. Use the amp as a 3 channel amp for the front stage only. That would have the amp pushing about 160WPC to the front stage with the Pioneer powering all 4 surrounds with about 114WPC there.
So, I'm initially leaning towards options 2 & 3. That leads me to wonder if it's better to get the extra power to the front stage and let the Pioneer AVR power the surrounds. Or, if that little bit of extra power isn't enough to pull the other speakers off of the amp. What do you all think?
Samsung 65" ES8000 LED
Pioneer Elite VSX-53
Polk RTiA5's - Front Towers
Polk CSiA6 - Center Channel
Polk RT15i's - Side Surrounds
Polk FXiA4's - Rear Surrounds
SVS PB-1000 - Subwoofer
URC MX5000 - Remote
Post edited by Jestered on
  • Glen B
    Glen B Posts: 269
    edited October 2013
    I would use the Emotiva on the 3 front channels, which have the greatest demand, and the Pioneer on the surrounds. The surrounds don't require that much power, and the Pioneer would be more than capable of the task.
  • Jestered
    Jestered Posts: 49
    edited October 2013
    Thanks for responding. If that's the case, would I be better off getting a 3 CH amp with more power compared to using this 7 CH amp with what it would provide as a 3 CH amp? I think I can get an Emotiva XPA-3 for about the same price, which would provide 200WPC to the front stage.
    URC MX5000 - Remote
  • CCNJ
    CCNJ Posts: 384
    edited October 2013
    I would tend to agree that I would want to provide more power to the fronts and center. I used to run a 5.1 setup with the xpa-3 powering the fronts. It is a more than capable amp and I was very happy with it especially at that price point.
    Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
    Rig2 - LFD LE IV Integrated, Harbeth P3ESR, Rega Dac, MF V-Link, IMAC, Audioquest Type4
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited October 2013
    3.
    Definitely
  • WLDock
    WLDock Posts: 3,073
    edited October 2013
    Jestered wrote: »
    Yes, the LPA-1 just not seem like the better logical upgrade choice. Save a little more and pick up the XPA-3 Gen 2 for $719 and enjoy the new front power that should drive your speakers to reference levels cleanly. Much better bang for the buck!
    Also, go listen to one of the Elite SC units if you have never heard one....It might suprise you? They tend to deliver clean rated power into all channels, Maybe one of those units alone will do it for you? The used maket makes these units killer deals.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited October 2013
    WLDock wrote: »
    After hearing so much here in CP forum within the last couple of years on the Pioneer Elite SC AVRs , it sounds like they do_ have a very nice,clean power amp section, maybe cleaner than Emotivas , DYODD.
  • Zoomzilla
    Zoomzilla Posts: 76
    edited October 2013
    Polkie2009 wrote: »
    As a new Elite SC owner I can attest to the clean power. Amazing compared to typical class AB amps
    tonyb Posts: 33,069
    edited October 2013
    No.3, which agree's with the above posters. Though I'm not so sure the Emo is a good pairing with RTI speakers.
