Binding Post for GFA-545
PreCd
Just purchased a GFA-545 and want to replace the binding posts. I would like posts with the option of spade or banana plugs. Any suggestions?
SDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp
Marantz CD5004
Adcom GFA-545
Post edited by PreCd on
WBT's are nice, as are Cardas. The latter comes in a gold plated copper billet available from www.sonicraft.com. Sonicraft has a 20% off sale right now."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Thanks for that PD!
Even more specific is this one, for their specials page: http://www.soniccraft.com/specials.htm
Scroll down to find the BP's on sale."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I have four silver 5-way posts left over from my SRS 2 rebuild, but I don't remember the brand. If you're interested, I can snap a picture and sell them cheap.
Thanks everyone for your suggestions:
zingo: What is a 5 way binding post? I have never had to replace the post and am learning about them.SDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp -
The binding posts I have are from Energy Speakers (I bought a bunch of them a while ago), and look very similar to these ones below. They work great, look much better than any older plastic or steel units, and are marked black and red which is great.
The term 5-Way comes from the number of potential connecting methods the binding post can accept. Most people will use either banana plugs, or horseshoe-shaped flat connectors called spade lugs on the ends of their wires. Bare wire can be stuck through the hole in the shaft (the hole is exposed when the post cap is unthreaded, and then your wire can be clamped by the tightened cap). This clamping approach can also be used with the terminal pin connections found on some speaker wire. The fifth connecting method doesnt find itself used much in modern audio applications, but the original General Radio product brochure described using alligator clips, which are spring loaded clips that have (you guessed it) gripping teeth. - Polk Audio's Website
