Integrated amps....
2
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited October 2013
    Vincent is great equipment and maybe something I'll buy one day.
    I know Doro likes them so that's saying a lot.
    tonyb Posts: 33,068
    edited October 2013
    Vincent.....not a fan. They look cool enough but not satisfied with the way they handle low bass. Very muddy sounding, slow, imho. That's just me though, others may dig them.
  • strider
    strider Posts: 2,568
    edited October 2013
    I always felt like the MF integrated that Miller Lite Scott has punched way above it's weight. Think he has the A308 if memory serves.
    Wristwatch--->Crisco
  • madmax
    madmax Posts: 12,434
    edited October 2013
    Tri-vista
    Vinyl, the final frontier...
    F1nut Posts: 51,695
    edited October 2013
    I always felt like the MF integrated that Miller Lite Scott has punched way above it's weight. Think he has the A308 if memory serves.[/Q]
    We did a cap upgrade on his MF. It's punching at an even higher level now :)
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited October 2013
    Garage | Polk Monitor 5B's
  • zingo
    zingo Posts: 11,258
    edited October 2013
    The HK990 looks wicked for $2000. RCA, XLR, and digital inputs with signal processing or analog pure direct. Power is 150wpc at 8 ohms, and doubling into 4 ohms (dynamic power rated at an additional 30%), with a maximum current rated at 200A. Maximum power consumption is 1000W, so seems to have a solid dual-transformer power supply with lots of power available to the amplifier section.
    http://www.harmankardon.com/estore/hk/us/products/HK-990/HK%20990_HK_US
    Overall, I was able to accomplish with the single-box HK 990 almost everything that I could with the combination of Meridian Reference 861, Parasound Halo JC 2 BP, and McIntosh Labs MC303. Was the H/K less potent than the Mac? Yes, but I had to force myself to listen at volume levels high enough that I could hear a difference—much higher than I would ever actually listen to music for pleasure. Was it less transparent than the Halo JC 2? Yes, but my ability to hear that difference depended on the recording. Was it less capable than the Meridian? Yes, the Meridian provides more channels and more processing options. Still, I could go from one setup to the other and not feel that the HK 990 was any less satisfying . . . with two-channel music. - Kalman Rubinson from Stereophile
    EndersShadow Posts: 17,687
    edited October 2013
    zingo wrote: »
    If it looks wicked @ 2k.... what does it look like at 1k?
    http://www.ebay.com/itm/Harman-Kardon-HK-990-150-Watt-Stereo-Integrated-Amplifier-/390686716195?pt=Speakers_Subwoofers&hash=item5af6be3123
  • zingo
    zingo Posts: 11,258
    edited October 2013
    txcoastal1 Posts: 13,500
    edited October 2013
    Been mentioned by Zingo, a bit over budget. This unit has plenty of power for anything you throw at it. I love mine
    http://app.audiogon.com/listings/solid-state-modwright-kwi-200-integrated-amplifer-2013-10-26-amplifiers-84111
    billbillw Posts: 7,476
    edited October 2013
    I'd be interested to know what you go with Troy. Keep us posted. I'm actually contemplating a change in that sort of direction also. I think my VK30/A21 setup may be overkill for the room I have and the type of listening I do these days. Also not excited about keeping stocks of good sounding NOS tubes for the VK30.
  • erniejade
    erniejade Posts: 6,321
    edited November 2013
    F1nut Posts: 51,695
    erniejade wrote: »
    Get it, you'll love it.......I guarantee it.
    F1nut Posts: 51,695
    Somebody just got one of the best integrated amps ever made.
  • NJPOLKER
    After taking a peek at the MF 300 it looks like a pre amp and an amplifier not really a IA
    Is that basically what it is? It really is nice looking OK beautiful
    NJPOLKER wrote: »
    Amp/preamp in one chassis=integrated amp. The MF has a separate power supply box for the transformers and rectifiers, but the preamp and amp are in the same box. Internally, the preamp section is on a separate board with nice quality jumpers in between. This is probably one of the best examples of how to do it right, but there have been many integrated amps through the years that have basically took an existing preamp design and stuck it inside the same chassis with an existing amplifier design.
    BTW, I was very, very close to throwing in a $2100 bid on that Tri-vista 300, but I decided to hold off and think about it for awhile longer.
  • erniejade
    If I didn't just get a McIntosh I would have jumped on it myself.
  • zingo
    zingo Posts: 11,258
    Decided to take Jesse's advice and give Musical Fidelity a try. This baby will be in the mail today and on it's way to my doorstep!
    A5.JPG 158.6K
  • Erik Tracy
    Erik Tracy Posts: 4,673
    A5 int - awesome choice! :cheesygrin:
    You are gonna love what this does for your 2-channel game!
  • zingo
    zingo Posts: 11,258
    I am interested to see what it does for my SRS 2 speakers, especially compared against the Dodd separates.
  • Erik Tracy
    Which Dodd separates do you have?
    The A5 will have plenty of grunt and control for the SRS 2s - so it should come down to what sonic signature you like.
    Be sure to post up your thoughts! Should be a fun comparison.
  • unc2701
    unc2701 Posts: 3,587
    Great choice. I've got the A5 pre & used an A5 int for a bit. Only issue I've had is that the phono stage died on it, which of course happened after I sold my Audio Research phono pre.
    Backburner:Krell KAV-300i
  • zingo
    zingo Posts: 11,258
    Dodd Tube Buffer preamp and Gary custom built, balanced power supply Hypex UcD400 based amp.
  • Erik Tracy
    Jake - so any update? Have you got the A5?
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    C'mon ya'll, everyone knows that Musical Fidelity is the undisputed king of high end integrated amps.
    +1 And the Tri-Vistas have little tubes made by elves in the Black Forest. :-) Cool factor off the hook.
  • decal
    decal Posts: 3,205
    Give the Rogue Audio Sphinx hybrid a listen if you can. http://www.needledoctor.com/Rogue-Audio-Sphinx-Integrated-Amp
    F1nut Posts: 51,695
    Tonight, in a dimly lit room, BDT is sitting in the sweet spot whacking it like a red a$$ monkey while repeating over and over, "M friggin F !!"
    tonyb Posts: 33,068
    Not so unusual for Troy.....lol
