Is this setup with wire and banana stuff good at all???
arufener
arufener Posts: 63
I recently got some new polk audio speakers. I am kinda on a budget, and want to get good cables and what not, but not spend a ton.
I bought this spoil of wire on ebay, it comes with banana plugs, but I bough some more.
Here is their links
Spoil---
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14966&item=5706220228
Plugs---
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=32838&item=5706594352
Are these good or bad, or what?
Sooner or later you're going to realize, just as I did, there's a difference between knowing the path...and walking it.
Post edited by arufener on
  • Willow
    Willow Posts: 11,228
    edited June 2004
    I use those plugs and they are good no probs with them
  • gidrah
    gidrah Posts: 3,049
    edited June 2004
    Those plugs look really good. I like the 10 awg ability especially. Even if you dont' use wire that thick you should have more surface area available for a better connection.
    Just be careful to not use them in a situation where they are too close to each other or could be jostled. They appear to be built so that the center pin is separated form the housing, but a stray strand could energize that housing. This done on + & - speaker terminals that are in close proximity, give them a twist to check out the back and buzz-zap - instant short. Be careful.
    Make it Funky! :)
  • Willow
    edited June 2004
    I have no probs the compression pushes all cable upwards around the top pin and not out the holes. very clean and easy to use
    you could use heat shrink to protect it all as well and make it look purrty
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2004
    They will work just fine.
  • Zen Dragon
    Zen Dragon Posts: 501
    edited June 2004
    Should have no probs. Acoustic research makes very solid useable products. They won't win any audio awards, but they are a good cut above generic wire. I have a set of AR interconnects from Best buy that I use for my sub and center outs from my SACD out to my receiver. For the price they are well built and don't appear to take anything away from the signal.
    The bannanas may have a propensity to loosen, especially if you are rocking the house. Give the screw on part a twist from time to time to see if it is loosening.
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
    This is pretty f***ed up right here.
  • arufener
    arufener Posts: 63
    edited June 2004
    thanks, I'll be keeping all of this in mind when I hook them up, (still waiting, items in shipping)
    thanks
    arufener
