got the carver tfm 35 up and running
scottyboy76
It really does not sound very diff. from the tfm 25 below it, definitely more power.
Sprayed it and the ct-3 i got with it with deoxit d5, i had forgotten the slight sorta oily film it leaves, guess that eventually drys completely.
BTW, the guy i got these from asked if i wanted to haul his old tv off, its a vizio 42 in. 1080p lcd.
He said one day the video just screwed up.
He had replaced it with a samsung, i said no, there werent any tv repair shops up here, but thanks.
While using his restroom, i started thinking, "You will always wonder and regret not just throwin it in the car, so i did."
At first, it had vertical gray and black lines over app. 80% of screen.
i said oh well i will ask charity thrift stores if they want it, left the room, came back in app.10 min. and boom, a perfect picture, in fact a surprisingly excellent picture for a cheaper lcd.
We used it for the next couple of days, and once or twice, it started out with problem, then cleared right up, after clearing up, it does not matter how many times we turned it on and off, pic was fine.
I have looked at a few sites that sell diff. replacement boards for this tv, with a 30 day return, very reasonable prices, will probably take a chance if necessary in the future.
humpty dumpty was pushed
Post edited by scottyboy76 on
Good deal Scott. Glad the Carvers are good and the tv is just a bonus. Will try to call you later today, just trying to catch up from being out of town for 3 days. Got a little surprise to send your way.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
we will be here, you know we stay up late, will tell deb to have the phone handy after we lay down to watch tv.humpty dumpty was pushed
Look for the thin ribbon cables that go to the circuit boards unplug them and clean them and reattachscottyboy76 wrote: »It really does not sound very diff. from the tfm 25 below it, definitely more power.
I have looked at a few sites that sell diff. replacement boards for this tv, with a 30 day return, very reasonable prices, will probably take a chance if necessary in the future.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
The Carvers Looks great Scott & freebee is always a plus
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Does it matter what i clean them with, would shack spray cleaner be suitable?
I have caig deoxit gold cleaner, im out of d5.humpty dumpty was pushed -
I just used a little paper alcohol wipes Scott and I noticed some black residue came off of them.scottyboy76 wrote: »Does it matter what i clean them with, would shack spray cleaner be suitable?
I have caig deoxit gold cleaner, im out of d5.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
