got the carver tfm 35 up and running
scottyboy76
scottyboy76 Posts: 2,905
edited October 2013 in Electronics
It really does not sound very diff. from the tfm 25 below it, definitely more power.
Sprayed it and the ct-3 i got with it with deoxit d5, i had forgotten the slight sorta oily film it leaves, guess that eventually drys completely.
BTW, the guy i got these from asked if i wanted to haul his old tv off, its a vizio 42 in. 1080p lcd.
He said one day the video just screwed up.
He had replaced it with a samsung, i said no, there werent any tv repair shops up here, but thanks.
While using his restroom, i started thinking, "You will always wonder and regret not just throwin it in the car, so i did."
At first, it had vertical gray and black lines over app. 80% of screen.
i said oh well i will ask charity thrift stores if they want it, left the room, came back in app.10 min. and boom, a perfect picture, in fact a surprisingly excellent picture for a cheaper lcd.
We used it for the next couple of days, and once or twice, it started out with problem, then cleared right up, after clearing up, it does not matter how many times we turned it on and off, pic was fine.
I have looked at a few sites that sell diff. replacement boards for this tv, with a 30 day return, very reasonable prices, will probably take a chance if necessary in the future.
humpty dumpty was pushed
Post edited by scottyboy76 on
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited October 2013
    Good deal Scott. Glad the Carvers are good and the tv is just a bonus. Will try to call you later today, just trying to catch up from being out of town for 3 days. Got a little surprise to send your way.
  • scottyboy76
    edited October 2013
    we will be here, you know we stay up late, will tell deb to have the phone handy after we lay down to watch tv.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited October 2013
    Look for the thin ribbon cables that go to the circuit boards unplug them and clean them and reattach
  • boston1450
    boston1450 Posts: 7,689
    edited October 2013
    The Carvers Looks great Scott & freebee is always a plus ;)
  • scottyboy76
    edited October 2013
    PolkieMan wrote: »
    Does it matter what i clean them with, would shack spray cleaner be suitable?
    I have caig deoxit gold cleaner, im out of d5.
  • PolkieMan
    edited October 2013
    I just used a little paper alcohol wipes Scott and I noticed some black residue came off of them.
