Need replacement. Midrange for Cs-350LS mw4850
BCWookie
I have a old Cs-350ls center channel and need to find a replacement midrange driver part number mw4850. Polk doesn't have any, none are listed on eBay. Does anyone know of a good compromise?...
I have found a cs150 on eBay which has a mw4800 and a mw4802. Does anyone know if one of these would work with the cs350.
Any help would be much appreciated!
Post edited by BCWookie on
buy a whole new/used CS350 and then you have spares. They go for about 100.00 on eBay you'll spend about 50.00 for the driver.
I have not been able to find a 350 on eBay. That's why I want to replace with a similar driver. Any suggestions?
Keep an eye out for LSfx's as well, same drivers.
There were 3 a few weeks ago have some patience.
ken brydson wrote: »Keep an eye out for LSfx's as well, same drivers.
be a real shame to sacrifice one of those for a driver. but yes you are right....but then the price just went up 300.00 for a set. -
Got mine for $100 shipped IIRC. Find a cosmetically challenged set (mine weren't) and you're golden.
