MFW-15 subwoofer death hum
mdaudioguy
mdaudioguy Posts: 5,164
edited October 2013 in Speakers
It was bound to happen eventually.... Turned on my system yesterday to hear some tunes and after the first song ended, there was a strange hum coming from the sub. Powered it off and on, still there. Powered off, unplugged the input cable, and powered back on again, to no avail. Still humming whenever powered and on. All the finger crossing and knocking on wood finally failed me after five years. So, now the (physically) biggest part off my HT sits dormant. Still contemplating my next move. I've read that the caps could be the problem, so maybe I'll try a recap and see how much more time that buys me.
  • erniejade
    erniejade Posts: 6,327
    edited October 2013
    I have a velodyne spl1200 ( great sounding sub btw) that developed a hum. I took it in and they did re cap it and did something with the power supply. It has been fine ever since and im going on 4 years since I had the work done.
  • rooftop59
    rooftop59 Posts: 8,120
    edited October 2013
    I am sure that you know that there is a guy on some forums that repairs and upgrades those amps (for a price of course): http://www.seaton-sound-forum.com/?forum=154357
    And of course you can always just build a plate or have your local metal shop make one (mine charges me 15 bucks) and run an external amp since your using a receiver. The hardest part of making a sub is building the enclosure properly matched to the driver, so even if the amp fails you still have something salvageable.
    Good luck and let us know how it works out.
    Game Room 5.1.4:
    Bedroom 2.1
  • Eocuph
    Eocuph Posts: 75
    edited October 2013
    I have a bunch of polk rt3000p's that have the same humming issue. It seems like it's a common issue with age.
  • rooftop59
    edited October 2013
    I actually don't think that it is age, but a QC problem with certain makes/models. I have had plenty of amps (sub and otherwise) that are much older and still fine. But Polks plate amps on their powered towers and pretty much every amp that AV123 made have this issue. Just whole batches of bad lemons...
    Game Room 5.1.4:
    Bedroom 2.1
  • Eocuph
    Eocuph Posts: 75
    edited October 2013
    Yeah I agree, that's a good point. There are 2 versions of the rt3000p amps and I wast told by "electrontix" from eBay (he repairs rt3000p's) that the issues are a lot less common with the newer models.
    I hope the humming sound is a cheap and easy fix for you so that you can continue enjoying your subwoofer:)
