Who has a tube tester
heiney9
heiney9 Posts: 25,498
edited October 2013 in The Clubhouse
I have a pair of =C= 6L6 power tubes and one is bad. I'm not sure which one. Is anyone capable of testing these so I can eliminate the bad tube?
Post edited by heiney9 on
  • george daniel
    george daniel Posts: 12,096
    edited October 2013
    If you cannot find anyone local send it to me
  • thsmith
    thsmith Posts: 6,082
    edited October 2013
    Might be able to use a VOM depending on the failure.
    edited October 2013
    Thanks George, I'll see what other offers I get.
    Tracy, not sure how I would do that. The offending tube can't be in the circuit more than a couple minutes. I start to smell the bias resistor (I assume) as it gets hotter and hotter so I am assuming the tube is drawing to much current or perhaps even shorting out. After a couple minutes the tube starts going to static and then eventually that channel no longer passes a musical signal all the while the "hot" smell gets worse.
  • sda2mike
    sda2mike Posts: 3,131
    edited October 2013
    I have one brock. its kind of simple. it will report shorts. it has a health meter. i can send it to you. that way you can check other suspects. its been pretty usefull
    pitdogg2 Posts: 27,319
    edited October 2013
    Somehow I would of thought you had one.........
