Who has a tube tester
heiney9
I have a pair of =C= 6L6 power tubes and one is bad. I'm not sure which one. Is anyone capable of testing these so I can eliminate the bad tube?
Post edited by heiney9 on
If you cannot find anyone local send it to meJC approves....he told me so. (F-1 nut)
Might be able to use a VOM depending on the failure.Speakers: SDA-1C (most all the goodies)
Thanks George, I'll see what other offers I get.
Tracy, not sure how I would do that. The offending tube can't be in the circuit more than a couple minutes. I start to smell the bias resistor (I assume) as it gets hotter and hotter so I am assuming the tube is drawing to much current or perhaps even shorting out. After a couple minutes the tube starts going to static and then eventually that channel no longer passes a musical signal all the while the "hot" smell gets worse."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
I have one brock. its kind of simple. it will report shorts. it has a health meter. i can send it to you. that way you can check other suspects. its been pretty usefull
Somehow I would of thought you had one.........
