squeezebox question
sda2mike
I moved my squeezebox and server to another room..now the squeezebox randomly cycles on and off, but picks up where the music left off. my firewall is on and allows Logitech through..all connections are secure..any ideas?
thanks
mike
thanks
mike
Post edited by sda2mike on
If the power cycles maybe a loose or poor power connection. Are you using the stock power supply or an upgraded one?Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
got it! it was the pwr jack..got it positioned just right, now..i had a sqbx 3 years ago with a bad pwr connection..just had to resolder and it was fine..some of the solder joints went bad
thanks
mike
