squeezebox question
sda2mike
sda2mike Posts: 3,131
edited October 2013 in The Clubhouse
I moved my squeezebox and server to another room..now the squeezebox randomly cycles on and off, but picks up where the music left off. my firewall is on and allows Logitech through..all connections are secure..any ideas?
thanks
mike
Post edited by sda2mike on
  • zane77
    zane77 Posts: 1,696
    edited October 2013
    If the power cycles maybe a loose or poor power connection. Are you using the stock power supply or an upgraded one?
    Two Channel
  • sda2mike
    edited October 2013
    got it! it was the pwr jack..got it positioned just right, now..i had a sqbx 3 years ago with a bad pwr connection..just had to resolder and it was fine..some of the solder joints went bad
    thanks
    mike
