Polk RTi A5 Tweeter Cutting In and Out
ThirdWorldGuy
ThirdWorldGuy Posts: 39
edited October 2013 in Troubleshooting
Hi,
The tweeter on my right RTi A5 connected to my HTPC via HDMI powered by a Yamaha RX-V767 rarely cuts out and I can't hear it.
During music listening or while playing videogames on the HTPC. I adjusted the volume a bit and it kicked right back in! This has happened about thrice now in the last month. I did, by the way, notice that one of the HDMI cables was a bit loose. I removed it and plugged it back in after cleaning the contacts but I hardly think that it's the HDMI's fault because I've heard if the connection is lose there will be no picture and no sound.
Also at first I thought that the tweeter was blown but according to some posts here if it were blown than it would make no sound at all. Also on one post I read that it might have something to do with the crossover. Is there something wrong with my receiver? Are the wire contacts oxidized(is that even a thing)?
Any idea whats wrong here? It's perfectly fine right now and sounds awesome.
Thanks in advance to everyone.
On a side not when I try to access the Polk Forums I get a message that the Administrator has banned your IP address. Contact webmaster here. I did contact him and the problem went away for 2 days but now again I'm getting this message and now I can only access the forums via a proxy server.
Although I did not get a reply from him on my email address that I gave.
Post edited by ThirdWorldGuy on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited October 2013
    Hello,
    If you look at the rear of the speaker's cabinet you will see two sets of speaker binding posts. Make sure the gold plated jumper plate is firmly in place. If the binding post caps seem tight, try unloosening all four binding post caps and use a good quality electrical contact cleaner (found at most electronic parts supply stores) to thoroughly clean all of the contact areas on the binding post shaft and the jumper plates.
    Regards, Ken
    F1nut Posts: 51,777
    edited October 2013
    Check the speaker cable connections on the back of your AVR as well.
  • ThirdWorldGuy
    edited October 2013
    Hi,
    Thanks for the replies guys,
    The gold plated jumper plate is firmly in place. I removed it and reconnected it and checked it's integrity. I believe it's fine.
    Although the gold plated jumper plate was slightly stained, I wonder what that is and how do I clean with contact cleaner? Dip a cloth in contact cleaner and rub it on the jumper plates?
    F1nut,
    I checked the speaker cable connections on the back of my AVR. Removed all the wires and put them back in. I think they're alright
  • [Deleted User]
    edited October 2013
    Hello,
    Usually electrical contact cleaner comes as an aerosol spray. You can either spray directly onto the jumper plate or spray onto a clean cloth and then wipe the plates.
    Cheers, Ken
  • ThirdWorldGuy
    edited October 2013
    Okay thanks Ken and also F1nut.
    Will do this and will report back if the problem persists.
  • ThirdWorldGuy
    edited October 2013
    nbrowser wrote: »
    Another solution would be to replace the jumper plates with short pieces of quality speaker wire and lose the plates entirely, just another suggestion.
    What would constitute as quality speaker wire? Sorry I'm a newb at this... Is Monster XP wire okay? I'm using it currently got it free with the speakers.
    F1nut Posts: 51,777
    edited October 2013
    At this point I suspect you have a cold (bad) solder joint on the crossover board or a loose connection at the tweeter.
    That will vary with experience, wallet and level of gear. That said, just about any speaker wire is better than those plated brass jumpers, but I don't think the jumpers are the cause of the issue you're having right now.
  • ThirdWorldGuy
    edited October 2013
    In that case I would have to open the tweeter assembly and check the loose connection or resolder something?
    BTW I've never used a soldering gun nor do I own one.
    F1nut Posts: 51,777
    edited October 2013
    There will be 2 wires connected to the tweeter coming from the crossover board. The connection is made with Faston (push on) terminals. Remove the tweeter assembly, pull the connections off and push back on again. Do not attempt to open the tweeter itself.
  • ThirdWorldGuy
    edited October 2013
    Sorry if I'm being thick but should I wait untill and if the problem recurs?
    F1nut Posts: 51,777
    edited October 2013
    Up to you.
  • ThirdWorldGuy
    edited October 2013
    I'll wait then, thanks F1nut for all the help so far.
  • ThirdWorldGuy
    edited October 2013
    Is 16 gauge alright? Or do I have to be sure to use 12 gauge or greater?
