Bookshelf T15
eric77
eric77 Posts: 2
edited October 2013 in Troubleshooting
I have 4 T15 bookshelfs that I use as my surround speakers and 1 of them stopped working and is making some static noise so im wondering if it can be fixed or if I can replace the speaker and or buy just 1 bookshelf. Thanks
  • Nightfall
    Nightfall Posts: 10,083
    edited October 2013
    Have you tried swapping another T15 with the broken one? Make sure it's the speaker and not the channel.
    afterburnt wrote: »
    Village Idiot of Club Polk
    gudnoyez Posts: 8,174
    edited October 2013
    Best Buy has sold these every Black Friday for the past couple of years if you can hold off they go for $50 a pair. Have you checked all your connections to make sure nothing is loose? Try swapping another T15 in its place, welcome to club Polk.
