Mitsubishi DA-15 Power Amp - any good?
Timothy Smith
One of these not too far from me for $300.
Back in the late 70's I wanted one of these so bad I could taste it.
Has anyone owned one or even listened to one?
I still think it's one of the coolest looking amps ever.
Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
Post edited by Timothy Smith on
That is one sexy amp!afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
It looks like it could be from Darth Vader's "man-cave" system on the Death Star.
Probably used to listen to Iggy and the Stooges and Lou Reed's Metal Machine Music.Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player -
I've heard good things, but be careful because the speaker cable connectors are the worst design I've seen. They use this screw connector, but as you tighten the knob which closes the little "door", it tends to push out the wire/pin. I've never pick-up that amp for that reason as I would have to replace convert the speaker outputs.
Couldn't agree more about the speaker cable connectors. I picked this up for $80 and had it gone over. It had no power switch at all so one was installed on the back. It no longer has connections for 2 pairs of speakers and a IEC was installed.
Because I am The Pumpkinking
A friend of mine has one of those with the huge meters that dock to the front of the power amp. Great sounding amp. I'm not familiar with the speaker connections. He never mentioned them.
Check out the attached link.
http://www.allegrosound.com/Mitsubishi_DA-M10.htmlMain System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
