Speaker Selection Help
I currently have a Denon 3802 receiver,RT55i & CS 400 front speakers and a 12" powered sub.I'm looking for options to expand into a 5-1,6-1 or 7-1 system.I don't know the best way to go or which speakers would work best.I'd appreciate any feedback that I can get.THANKS
Post edited by bkfk on
You have Tri Lam tweeters. Anything you choose should have the same.
Check these
They are all out of production, but can be had. -
RT38i's would be a perfect match up for surround speakers. they use same tweeter and 6.5" driver that is in your front/center speaker. You could...if you like..find another pair of 55i's...I use those for surrounds myself..
good luck -
I think he meant RT35i will match. And I would second that suggestion.Home:
Denon AVR-1803
Polk CSi30
Polk RTi70
Polk RTi28
Polk PSW-303
Car:
Kenwood KDC-BT945U
RF Punch P400-4
Polk MM6501
Polk MM651
RF Punch P300-1
Boston Acoustics G312-4 -
35's..yes...why did I say 38? someone shoot me
