Speaker Selection Help
bkfk
bkfk Posts: 44
edited June 2004 in Speakers
I currently have a Denon 3802 receiver,RT55i & CS 400 front speakers and a 12" powered sub.I'm looking for options to expand into a 5-1,6-1 or 7-1 system.I don't know the best way to go or which speakers would work best.I'd appreciate any feedback that I can get.THANKS
  • amulford
    amulford Posts: 5,020
    edited June 2004
    You have Tri Lam tweeters. Anything you choose should have the same.
    Check these
    They are all out of production, but can be had.
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited June 2004
    RT38i's would be a perfect match up for surround speakers. they use same tweeter and 6.5" driver that is in your front/center speaker. You could...if you like..find another pair of 55i's...I use those for surrounds myself..
    good luck
  • bokdaddy
    bokdaddy Posts: 176
    edited June 2004
    I think he meant RT35i will match. And I would second that suggestion.
    Home:
    Denon AVR-1803
    Polk CSi30
    Polk RTi70
    Polk RTi28
    Polk PSW-303
    Car:
    Kenwood KDC-BT945U
    RF Punch P400-4
    Polk MM6501
    Polk MM651
    RF Punch P300-1
    Boston Acoustics G312-4
  • TrappedUnder Ice
    edited June 2004
    35's..yes...why did I say 38? someone shoot me
