Tuning D4000.4 amp
Philbert
Philbert Posts: 2
Hi all,
I just installed a D4000.4 amp and DB6501 speakers. I'm looking at the instructions for tuning the amp and it's not making sense to me. In step 5, it says "turn up the level control corresponding to the midrange output...", again for the tweeter in step 6 and finally for the woofer in step 10. There are not separate tweeter, midrange and woofer level pots on the amp. What am I missing here?
  • WLDock
    WLDock Posts: 3,073
    edited September 2013
    All its saying is:
    1) Adjust both the amps level controls to minimum.
    2) Adjust the deck's volume to 3/4 of max.
    3) Adjust the CH 1 & 2 level control until you heard distortion then back it down.
    4) Adjust CH 3 & 4 level control until......
    5) Then, balance the tweets output with the mid.
    5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3
  • Philbert
    Philbert Posts: 2
    Ah! That makes sense.
    What I was missing: the instructions were written to apply to various connection configurations, including ones in which the tweeter, midrange and/or woofer are on separate channels. I did not consider that a speaker system might be set up that way.
    Thanks for the clarification.
    Philbert
    WLDock wrote: »
    All its saying is:
