Can cs400 center speaker hold tv weighing 50 lbs?
Kenshin Himura
Kenshin Himura Posts: 23
edited September 2013 in Speakers
cant find any info on this searching the web. the speaker weighs in the 20+ lbs range so i would think it has a wood construction. i dont have a lot of space, so if it can hold up the tv that would be perfect.
Post edited by Kenshin Himura on
  • nguyendot
    nguyendot Posts: 3,594
    Should hold it fine, assuming the stand fits on it
    Main Surround -
  • Kenshin Himura
    stand width to practically the same and smaller depth so thats not a problem. only thing that worried me was it being too heavy.
  • ken brydson
    ken brydson Posts: 9,006
    I'd be concerned with the stability...
  • Geoff4rfc
    Geoff4rfc Posts: 2,855
    Have you considered building a shelf around the CC so the TV can sit on top of that? Easy fix, one board on either side of the CC, one across the top to join them and presto, a three sided shelf that fits over the CC for the TV to sit on.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • Nightfall
    Nightfall Posts: 10,084
    No part of the TV's stand overhangs the edge of the speaker? I don't think you're going to bust it with 50 pounds. I bet you could stand on the speaker and it wouldn't break. My 46" TV is on my Monitor 5's, no problem. I realize they aren't a CS400, just giving you my experience.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Kenshin Himura
    Nightfall wrote: »
    not really. cs400 measures 18" across and my stand is 18 1/2" so that works out pretty good.
  • Eocuph
    Eocuph Posts: 75
    Those cs400's are built and braced well.
    It can handle a lot more then just a tv.
  • Polkie2009
    Polkie2009 Posts: 3,834
    Thanks a heck of a center channel setup you have there Kenshin, how does it sound? Might be interesting to try two CS400's like this.:cheesygrin:
  • Tornado Red
    Tornado Red Posts: 939
    It's all about weight distribution, sounds like your tv has a fairly wide stand which will spread the weight over that distance. That will make the weight per square inch certainly doable by the sounds of it. As long as, like Ken says, the stability is good and since the center channel is about the same size, it should be. I remember about 25 years ago or so when water beds were all the rage and people worried about the weight on their floors. In MOST cases (depending on design and size of the frame the bed was on) there was actually less weight per square inch on the bedroom floor than the refridgerator was putting on the kitchen floor. Anyway, if your center channel collapses this conversation never happened :cheesygrin:
  • Polkie2009
    TR, "if your center channel collapses, this conversation never happened", lol. And the Secretary will disavow any knowledge of your actions or whereabouts.:cheesygrin:
  • Kenshin Himura
    Polkie2009 wrote: »
    i'll let you know when i get it in. bought it off ebay this morning with approximate delivery for next wednesday.
    :cheesygrin:
  • Mystery
    Mystery Posts: 2,546
    You can also assist with furniture raisers on the back so the TV stand also has support from the raisers if the stand goes that far back.
  • WLDock
    WLDock Posts: 3,073
    That speaker is solid. I seriously doubt there would be any issues.
  • Kenshin Himura
    great. cant wait to receive it now.
  • jbooker82
    jbooker82 Posts: 1,627
    I would build a shelf. All you need is a couple hardwood stair treads. Use one as the top deck and cut the other one for side legs. They should the smooth rounded front so they will look nice. Most speakers are made out of MDF and would trust a hard wood shelf before a MDF box.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • teekay0007
    teekay0007 Posts: 2,289
    jbooker82 wrote: »
    +1 to this, but I'd also put a back on the shelf for added stability so it wouldn't sway and collapse. Having a back would also make cable concealment much easier. A shelf would also protect the speaker top from getting all scratched up from the TV stand and if you made the shelf high enough, you'd be able to elevate the front of the speaker to aim it into your seating area better. I've found this makes a big difference in sound quality with my two CS400s.
  • WLDock
    WLDock Posts: 3,073
    A shelf/ TV Riser is always a nice way to go....especially a custom job. If one is not a DIY'er this is a nice and inexpensive one that looks big enough (23.63W x 15.75D x 9.25H) to house the CS400 (18 3/4"W x 14"D x 8 5/8"H)
    Convenience Concepts Designs2Go 2-Tier Swivel TV Stand
    http://www.amazon.com/Convenience-Concepts-Designs-2-Go-2-Tier-Swivel/dp/B000W9TVJ0/ref=sr_1_2?ie=UTF8&qid=1378425783&sr=8-2&keywords=TV+riser
    http://www.avsforum.com/t/1390240/get-your-tv-off-your-center-channel-with-this-stand
    http://tvriser.net/convenience-concepts-2-tier-swivel-tv-riser/
  • Kenshin Himura
    thanks wldock. very interesting.
  • Geoff4rfc
    jbooker82 wrote: »
    That's an awesome idea, too bad I didn't think of that.....wait, I did, right after Kens comment :mrgreen:
    Set up:
  • teekay0007
    Geoff4rfc wrote: »
    jbooker82 wrote: »
    Good on you, Geoff, and a +1 to you too since I gave jbooker82 a +1 above. He did, in all fairness, expand on your idea, so he keeps his +1 too.
    And I expanded on jbooker82's idea, so +1 to me too! Yay! :loneranger:
  • Geoff4rfc
    Lol, right on teekay, I was just messin.
    Set up:
  • evertune
    evertune Posts: 8
    No over hand and make sure your sub does not move things around.
