MIT EXP2 Cable Problem
So it seems I have a problem with one of my MIT EXP2 cables. There seems to be a short or a broken connection near the end of the left positive cable going into my amp. The left speaker doesn't work until I fiddle with that connectin. It then works intermittently. When I switch the cables from left to right, just to make sure it's not the amp itself, I get the same results.
Looking at my set up, below, anyone have some advice on a comparable cable?
Maybe this is a time to experiment with some non-fancy-schmacy wire just for kicks? What gauge would I use for about a 10 and a 20 foot run?
Thanks.
Thanks.
“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
- Isaac Asimov
Hi-Fi
Visuals
They have a lifetime warranty, so call MIT at 916-625-0129. Lisa will tell you what you need to do.Political Correctness'.........defined
President of Club Polk -
Thanks F1 !“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
