SDA compliant amps / recievers
Bacchus
Bacchus Posts: 20
edited September 2013 in Vintage Speakers
as most here already know polk SDA speakers require a "common ground" amp. They say that MOST are common ground amps but some how I just seem to know how to pick them. Seems to me this site needs a data base of common ground and non common ground amps and receivers to make this a bit less painfull for those with newly aquired SDA speakers...
please cut copy and paste the running list and add to it. please don't post until you are sure.
non - common ground amps - don't use with your SDA's
1. Sansui B-2101 power amp
2. Sansui au-g99x integrated amp
3. adcom 7500 5ch power amp
Common Ground amps -- YAY !!! - go for it
1. Adcom gfa 555
Post edited by Bacchus on
  • boston1450
    boston1450 Posts: 7,473
    You can take a peek around and see other forum members signature which also may give you idea's what they are using. There may be archived threads also. The internet is a good tool GLWYS
    Randy/Maine
  • drumminman
    drumminman Posts: 3,396
    Most amps are common ground these days. The safest thing to do is to contact the manufacturer of the amp you're considering and ask.
    An alternative is to measure between the negative speaker terminals with a digital VOM. You can do a search to learn how.
  • zingo
    zingo Posts: 11,258
    drumminman wrote: »
    Works every time.
  • Schurkey
    Schurkey Posts: 2,100
    The early versions of the Carver M1.0 had one channel that was inverted. The polarity was made right at the output by swapping the red + and black - caps for the speaker wire connections. Inverting one channel was a trick to get more power from the power supply on heavy bass tracks. Bass is usually recorded monophonically, even on stereo recordings. With one channel inverted, a bass transient pulled power from both the + and the - power supply capacitors equally. THESE AMPS CANNOT BE MADE COMMON-GROUND.
    Later versions of the M1.0 had both channels in phase. These M1.0s are common ground UNLESS THEY'VE BEEN BRIDGED TO MONO.
    They can be identified by the order of the red and black knobs at the output terminals. Looking at the rear panel, if the output terminals are
    Black Red Black Red the amp is an early, inverting, non-SDA-compatible unit.
    Red Black Black Red the amp is a later, non-inverting, SDA-compatible unit.
    http://thecarversite.com/yetanotherforum/default.aspx?g=posts&t=3876 especially post #6
  • drumminman
    Schurkey wrote: »
    Interesting, clever design feature- didn't know that.
  • Schurkey
    Copy of e-mail received from a question about common-ground sent through the Adcom web site:
    Dear Schurkey,
    There is no common ground into the GFA 5500 model.
    You can look for GFA 555se which is higher power with common ground terminals included.
    http://www.adcom.com/products.html?page=shop.product_details&flypage=flypage.tpl&product_id=73&category_id=28
    Thank you.
    Sunil
    Everest World Co.,Ltd.
    18/8 Fico Place Building, 2nd Fl.,
    Sukhumvit 21 Rd., Wattana,
    Bangkok 10110, Thailand.
    Mob.+66 8 70035217
    ' +66 2 204 2255 | F +66 2 204 2259
  • drumminman
    Where is Adcom made? I thought they were an American company, yet you get a reply from a person in Thailand. Outsourcing CS, or that's where manufacturing is?
    heiney9 Posts: 25,082
    Adcom hasn't been made in the States for atleast a decade and a half. They have been sold a few times, not the same company it was in the early days. Not saying the gear is bad, just that the "original" Adcom is far removed from today's company. But, many similar companies suffered that fate.
  • Schurkey
    I have four Adcom GCD-600 carousel CD changers, (two of them in operating condition, two with problems to the analog circuitry that I'm not smart enough to fix) strongly preferred over the newer but similar GCD-700 because the earlier units are Japanese rather than Chinese origin like the later units. They may not be American or North American, but at least they're from the "Free World".
    Far as I know, Adcom--like Harman-Kardon, Rotel, Parasound, newer Carver gear, and so many others, but UNLIKE Acurus, B&K, and Bryston, for example--has outsourced the actual building of components to Asia for decades if not "forever". Were the famous GFA-555s and '555 IIs made in America? I doubt it.
    The only thing that surprised me was that they freely acknowledge the outsourcing of the customer service. Perhaps Adcom is now owned by an Asian holding company.
  • zingo
    zingo Posts: 11,258
    Does anyone know if two OEM ICEpower modules can be strapped together to create a common ground stereo amplifier? I believe W4S amps are common ground, but their production amp does not use stock modules either.
  • oldmodman
    oldmodman Posts: 740
    If you want to use a pair of monoblocks, are they common ground?
    Or does it make a difference if they are tube or transistor?
    Since they are both plugged into a "common ground" does that make them a common ground?
    Like the amps that nooshinjohn made, the Carver Statement Moniblocks, which I assume are common ground.
  • zingo
    zingo Posts: 11,258
    The common ground that SDAs need is that the negative binding posts between the two channels have to have continuity, and zero, or close to it resistance. Some monoblocks can have the negative binding posts "strapped together" with a piece of speaker wire or something similar to create an electrical common ground, but ALWAYS check with the manufacturer; the output device whether tube or transistor does not matter.
  • lardogthemarine
    Is a Yamaha M2 a common ground amp?
  • Schurkey
    Put an ohmmeter across the negative terminals of the two channels, and find out. Or post a schematic.
