Choose your subwoofer: Rythmik or SVS (Auburn, WA pickup)
jephdood
I'm selling one subwoofer and keeping the other. I'm not picky and don't care which. Here's what I've got:
1. Rythmik Audio F15
Driver - 15" high excursion with custom sensing coil
Driver materials - Black anodized aluminum with rubber surround
Cast aluminum basket
Aluminum flux modulation shorting rings
Amplifier - 370w RMS class A/B patented servo controlled
Dimensions - 19"(W) x 19 " (H )x 20 "(D) - (21-1/2" D with grille)
Shipping Weight - 102 lbs
Frequency Response - 14 - 200 Hz (-2 dB @ 14 Hz) with LFE inputs in A370PEQ3/XLR2/XLR3
14 - 90 Hz (-2 dB @ 14 Hz) with LINE IN inputs in all models
Crossover slope - Selectable 12 or 24 dB / octave (PEQ and XLR versions)
Crossover range (Low pass) - 25 - 100 Hz
Rumble Filter (High pass ) - 20 Hz 18 dB / octave
Phase response - 90 degrees phase shift at 20 Hz
Phase adjustment - 0 - 180 degrees continuously variable
Bass damping factor settings - high (Q=0.5), med (Q=0.7), and low (Q=1.1)
Finish - Black oak
2. SVS 20-39PCi
320 watt RMS BASH amplifier
20 Hz extension quasi-anechoic
+/- 3 dB 20 Hz-100 Hz
39" tall, 16" in diameter
Custom built SVS long-throw 12" driver
SVS designed, full-featured 320 watt Bash (R) digital switching amp
Built-in flush-mount amp configuration (220v. version available)
Computer Assisted Design (CAD) cylindrical enclosure
Exclusive SVS down-firing woofer with integrated base-plate
Compliant disk floor mounts, very low center of gravity
Precision tuned high-flow 4" flared port
Resonance free, protective top port grill
New 16" ultra high-strength custom drawn, polymer wrapped, enclosure tubing
CNC'd and cold laminated, 1.0" black composite end-caps
Extra heavy duty 8ft power cord
Architectural-grade black fabric exterior
The SVS is $450 and the Rythmik is $750. Those prices are FIRM.
Both subs are in perfect like-new physical condition and operate as new. I have the original box and packing for the Rythmik... I don't have the box for the SVS. FYI, the Rythmik has the silver driver as opposed to the black-- a more expensive option for whatever reason.
PM me with questions.
Finish - Black oak
2. SVS 20-39PCi
"I did not slap you. I high-fived your face."
Post edited by jephdood on
man, selling anything on this forum is worse than trying to sell on ebay or craigslist.... you never know how ridiculous the lowballers will be..
Last chance on the Rythmik. Someone scheduled to look at the SVS tomorrow."I did not slap you. I high-fived your face."
