Choose your subwoofer: Rythmik or SVS (Auburn, WA pickup)
jephdood
jephdood Posts: 1,691
edited August 2013 in For Sale (FS) Classifieds
I'm selling one subwoofer and keeping the other. I'm not picky and don't care which. Here's what I've got:
1. Rythmik Audio F15
Driver - 15" high excursion with custom sensing coil
Driver materials - Black anodized aluminum with rubber surround
Cast aluminum basket
Aluminum flux modulation shorting rings
Amplifier - 370w RMS class A/B patented servo controlled
Dimensions - 19"(W) x 19 " (H )x 20 "(D) - (21-1/2" D with grille)
Shipping Weight - 102 lbs
Frequency Response - 14 - 200 Hz (-2 dB @ 14 Hz) with LFE inputs in A370PEQ3/XLR2/XLR3
14 - 90 Hz (-2 dB @ 14 Hz) with LINE IN inputs in all models
Crossover slope - Selectable 12 or 24 dB / octave (PEQ and XLR versions)
Crossover range (Low pass) - 25 - 100 Hz
Rumble Filter (High pass ) - 20 Hz 18 dB / octave
Phase response - 90 degrees phase shift at 20 Hz
Phase adjustment - 0 - 180 degrees continuously variable
Bass damping factor settings - high (Q=0.5), med (Q=0.7), and low (Q=1.1)
Finish - Black oak
2. SVS 20-39PCi
320 watt RMS BASH amplifier
20 Hz extension quasi-anechoic
+/- 3 dB 20 Hz-100 Hz
39" tall, 16" in diameter
Custom built SVS long-throw 12" driver
SVS designed, full-featured 320 watt Bash (R) digital switching amp
Built-in flush-mount amp configuration (220v. version available)
Computer Assisted Design (CAD) cylindrical enclosure
Exclusive SVS down-firing woofer with integrated base-plate
Compliant disk floor mounts, very low center of gravity
Precision tuned high-flow 4" flared port
Resonance free, protective top port grill
New 16" ultra high-strength custom drawn, polymer wrapped, enclosure tubing
CNC'd and cold laminated, 1.0" black composite end-caps
Extra heavy duty 8ft power cord
Architectural-grade black fabric exterior
The SVS is $450 and the Rythmik is $750. Those prices are FIRM.
Both subs are in perfect like-new physical condition and operate as new. I have the original box and packing for the Rythmik... I don't have the box for the SVS. FYI, the Rythmik has the silver driver as opposed to the black-- a more expensive option for whatever reason.
PM me with questions.
"I did not slap you. I high-fived your face."
  • whitecamaross
    whitecamaross Posts: 219
    edited August 2013
    man, selling anything on this forum is worse than trying to sell on ebay or craigslist.... you never know how ridiculous the lowballers will be..
  • jephdood
    edited August 2013
    Last chance on the Rythmik. Someone scheduled to look at the SVS tomorrow.
