Connecting AVR to Amp - what RCA cables to use
Sumerian
Sumerian Posts: 490
edited September 2013 in Basic Hookup/Wiring Questions
Hello folks here comes another thread on cables
I would be connecting my AMP Parasound Halo A51 to Receicer Onkyo 709.
My receiver has RCA pre outs.
I dont want to spend a lot on these cables as i am planning to upgrade my receiver some time in near future and want to use XLR connections when i do so.
any suggestions on decent RCA cables which would complement my setup ot atleast which will not screw up my setup.
I would be using MIT S3 cables between my Amp and LSIM speakers.
Thanks in advance appreciate any suggestions and recomendations.
Post edited by Sumerian on
    tonyb Posts: 33,072
    edited August 2013
    Signal cable analog 2's......or give our own Doug a shout out.
  • Sumerian
    Sumerian Posts: 490
    edited August 2013
    tonyb wrote: »
    Thanks Tony, you are always quick helping fellow polkies...
    Just curious , Is Doug member of this forum?
    tonyb Posts: 33,072
    edited August 2013
    Yes, he is. Here's his web site.
    http://www.douglasconnection.com/
    EndersShadow Posts: 17,704
    edited August 2013
    tonyb wrote: »
    I concur with Tony. Frank at Signal Cable gives Polk Forum members a discount. I would go with his HT Analog 2 setup (link here). Saves you from buying 3 sets of cables and ending up with an extra. Doug's username is helipilotdoug.
    I have had both cables in my system and I prefer Dougs, but they are a little bit more. However they may be the last set of Interconnects you need, and he also makes XLR's so who knows maybe a deal could be struck to return some of his RCA IC's and get a reduction in the cost of some XLR IC's.....
  • Glen B
    Glen B Posts: 269
    edited August 2013
    Sumerian wrote: »
    I'm just curious why you've predetermined the need to use XLR cables in the future ? Unless all of your equipment will be truly balanced from input to output, using balanced connections realizes no benefit, except with long cable runs, to eliminate noise pickup. AVRs that are truly balanced are few and far between. If you are going to be using one with XLR outputs as a preamp, chances are it will be single ended internally, with balanced converters on the outputs.
  • Sumerian
    Sumerian Posts: 490
    edited August 2013
    DSkip wrote: »
    How's about $120 for a quad of MIT EXP1 and another quad of MIT EXP3? Shipping/PP extra, but this will cover all 5 channels plus an analog input. Should be more than enough to cover you until you get XLR's, and they should pair well with the speaker cables.
    So we are talking about 8 RCA connections right?
  • Sumerian
    Sumerian Posts: 490
    edited August 2013
    Glen B wrote: »
    That what i thought initially but from what i have read looks like people did noticed considerable difference ?
  • Sumerian
    Sumerian Posts: 490
    edited August 2013
    DSkip wrote: »
    Yep. Four total pairs.
    Your inbox is full.
    Thanks for of the offer let me shortlist my options and i will get back to you.
  • Spiffyfast
    Spiffyfast Posts: 35
    edited August 2013
    Blue jeans cables is my favorite
    Mains: Polk Audio SDA-2Bs
    Center and Surrounds: Bic Acoustech
    AVR: Pioneer 1015tx
    Amp: Anthem Amp 1
    Turntable: Project Debut III
    Inputs: Xbox 360, Samsung BDP-1000, Apple TV
  • CoolJazz
    CoolJazz Posts: 572
    edited August 2013
    Glen B wrote: »
    There's that often repeated line, that simply isn't true! Maybe if it's said often enough it gets more true....
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • Glen B
    Glen B Posts: 269
    edited August 2013
    Please explain what sonic benefit there is to driving internally unbalanced gear featuring balanced buffer/converters through 3 or so feet of interconnect? There is nothing in the descriptions of the A21 amp to indicate it is a full differential balanced amp.
  • Elementtw1023
    Elementtw1023 Posts: 15
    edited August 2013
    Audioquest King Cobras sounded wonderful! Just my 2¢
  • CoolJazz
    CoolJazz Posts: 572
    edited August 2013
    Glen B wrote: »
    The real big one is that the units are forced to share ground currents with single ended interconnect.
    Another is that the receiving unit starts with twice the audio level even assuming each leg was designed with the same output level as the unbalanced design would have used.
    Now as to the almost certain negatives of a fully balanced unit....
    Each and every component must have every internal part matched to the opposite phase sides complementary part. This match must be to a very high tolerance as every bit of mismatch contributes to a distortion. Hmmm....
    As to the idea that a balanced in only has more parts in the path than the"fully balanced" design...doesn't the fully balanced unit on the input also not have a common mode reject stage? How much design difference and parts count difference is their then between the them?
    I'm not saying fully balanced is necessarily a bad thing despite what I'm trying to call attention to. I'm simply saying this belief that you must from one end of the system to the other be fully balanced to have benefits is simply not true. And that the manufacturer of the internally single ended system isn't running a fraud on the unsuspecting. Some of the very, very best gear has balanced connections and is not running symetrical internal designs.
    CJ
  • Speedskater
    Speedskater Posts: 495
    'CoolJazz' that is one excellent explanation!
    tonyb Posts: 33,072
    My take on it, from my experiences with balanced is the fully balanced systems have a remarkable low noise floor, which is the intended purpose anyway. Half balanced systems, not point to point between all equipment, can have a better noise floor but not as good as fully balanced. When compared to non balanced gear, the difference is almost negligible.
    With that in mind, I find the variety of balanced cables out there are nowhere near whats available for standard RCA's. Plus they seem to be more expensive. After all, standard rca cables are in sorts a form of tone control and noise rejection depending on build of course. Those old tone controls on gear introduced lots of noise to the signal path which is why you don't see them anymore. Cables have in essence taken their place. I would much rather have the choices available for something like tone control over noise reduction which I feel is more readily apparent in one's system.....more easily heard. Just my .02 on it, you may disagree and that's cool too. Fully balanced comes in at higher end very sensitive gear where every bit of noise is audible.
    heiney9 Posts: 25,437
    In my rig I actually prefer the single ended sound vs. balanced and I am able to be fully balanced (pre to amp) not dac. But at one time I did have a balanced version of my dac. Just didn't float my boat like single ended. Don't prejudge and always assume balanced will sound the best. Be sure and explore all avenues and decide based on what you hear with your rig, in your room, with your music from your listening position. Nothing can be predetermined in this hobby. Everything matters.
    P.s. I used the same exact model cables for single ended and XLR (MIT Terminator II's).
  • BlueFox
    BlueFox Posts: 15,251
    SamanthaS wrote: »
    OMG, yes I agree, thanks CJ, one great explanation and just the help I needed!
    This is spam with a hidden link. I removed it for this reply.
    tonyb Posts: 33,072
    Brock,
    I too prefer the single ended approach. In all the balanced systems I've heard, there's a certain level of musicality missing. Could be just me though. Whatever floats your boat, the more revealing your system is, the more that noise floor becomes audible.
  • helipilotdoug
    helipilotdoug Posts: 1,230
    We are also glad to give Club Polk Members a discount. If you need something please contact us. :biggrin:
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    Yes, my apologies Doug, didnt meant to imply you dont give us Polkies a us a discount.
