Physics question about ohms
Ducati Guy
Ducati Guy Posts: 160
edited August 2013 in Speakers
So with wires 12 gauge wires are thicker than 18 gauge. Smaller gauge =thicker wire
Ohms are the measure of electrical resistance in a circuit.
So which speakers have more electrical resistance, 4 ohms or 8 ohms?
Is it the "opposite" like how wire gauges are measured?
I'd like someone with an engineering background to explain this?
And if 4 ohm speakers have less electrical resistance why do they make amps work harder/run hotter?
Please answer if you're only 100% certain of the science. I am wanting to better learn these basic concepts.
Post edited by Ducati Guy on
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2013
    Yes sir. Whatever you say.
    I=E/R. 'I' = current, 'E' = voltage, 'R' = resistance.
    'I' is inversely proportional to 'R'. 'R' goes down, 'I' goes up.
    SCompRacer Posts: 9,110
    edited August 2013
    A good page to explain Ohms and impedance.
    http://www.prestonelectronics.com/audio/Impedance.htm
  • nguyendot
    nguyendot Posts: 3,594
    edited August 2013
    Lower impedance = lower resistance (lower ohms). Means the restriction on your receiver to put out power is lower....demanding more power. More power = more heat = more stress on a receiver/amp.
    It's like running down a hill...that's too steep.
    Main Surround -
  • Ducati Guy
    edited August 2013
    Yes even with a question at 1am, you guys come thru, thanks.
    So, 4ohm speakers have less resistance than 8 ohms,
    and this allows more electricity to flow from the amp,
    thus a hotter running amp.
    Is my flow of logic correct?
  • Speedskater
    Speedskater Posts: 495
    edited August 2013
    Yes but it's tricky.
    The lower the load resistance (really it's impedance) the more current can flow (at whatever voltage) so more current times voltage equals more power.
    Now with the wires. They are not the desired load, so we use a different formula. The bigger the wire, the less it resists current flow to the desired load.
    Now as to the "hotter running amp" part.
    Modern amps are often least efficient at about 1/3 power. That's why the old FTC test rule required pre-conditioning the amp at 1/3 power steady for 1/2 hour. The Stereophile tests often write about amps that fail this part of the test.
    But in general, low resistance loads run hotter.
    Note that:
    Low impedance loads use more current & less voltage.
    High impedance loads use more voltage & less current.
  • Ducati Guy
    edited August 2013
    So impedance is the same thing as resistance, right?
    So what's the definition of current?
    And
    What's the definition of voltage?
    mhardy6647 Posts: 34,994
    edited August 2013
    Impedance is the AC analog of resistance and it obeys Ohm's Law.
    The trick about impedance is that it is (in a mathematical sense) a complex quantity with three components, resistance, inductance, and capacitance. Resistance is independent of frequency (and you'll see it referred to as "DC resistance" in discussion of speakers and crossover components), but capacitance and inductance are frequency-dependent. This is why we talk about the "nominal impedance" of a loudspeaker system or a speaker driver.
    The "complex" part is that these components (inductance and capacitance) are vectors not scalars - both the amplitude and phase are important to the contribution of inductance and capacitance to the impedance at any given frequency for a wire, or a coil (choke) or a resistor or a capacitor or what-have-you. This is part of what makes loudspeaker (and crossover) design so much fun! :-)
    EDIT: Current describes the rate of transfer of charge 1 ampere = 1 coulomb of charge per second
    Here's a really good tutorial (IMO) on the subject of measuring Thiele-Small parameters which, if nothing else, illustrates the frequency dependence of impedance for a speaker driver (woofer) and should give you some sense of why the impedance curve varies as it does.
    http://sound.westhost.com/tsp.htm
    Lots of interesting articles, projects and designs on that site, BTW.
    EDIT:
    Voltage is a measurement of electrical potential (electromotive force): one volt is the amount of potential difference required to develop a current flow of one ampere through a resistance of one Ohm.
  • stretchl
    stretchl Posts: 1,334
    edited August 2013
    I sense a student with a paper due this morning!
    - Isaac Asimov
    Hi-Fi
    Cabling by Groneberg
    Visuals
    edited August 2013
    Ohm's law is often described by analogy of the flow of water through a garden hose.
    The resistance is analogous to the diameter of the hose
    The voltage is analogous to the water pressure
    The current is analogous to the flow rate of the water through the hose
    http://www.allaboutcircuits.com/vol_1/chpt_2/2.html
  • nwohlford
    nwohlford Posts: 700
    edited August 2013
    You can think of impedance as being the AC equivalent of DC resistance (i.e., the opposition of current flow for a given voltage). It includes the effects of the capacitance and inductance in the circuit have in opposing the flow of current.
    Current is the flow of an electric charge. (It is often misstated as the flow of electrons.)
    Voltage is best thought of as the electric potential difference between two points. In audio system, it would be the difference between the positive and negative. (In most, cases the negative is ground.) If there is a voltage difference between two points in a circuit, then current will flow.
    In simple terms in an audio system, the amplifier takes the signal input to it and increases the voltage by some set gain (usually somewhere 20-35 dB). The speaker's impedance is the load (or opposition to current flow through the circuit). The lower the opposition the higher the current flow will be (i.e., lower impedance means higher current). Of course, if the amplifier can not supply the needed current that is when you have clipping. (You can also have clipping on the voltage side.)
  • BlueFox
    edited August 2013
    Ducati Guy wrote: »
    And
    There is a new and very useful tool called 'Google'.
  • Jhayman
    Jhayman Posts: 1,548
    edited August 2013
    Rofl....good one Bluefox although I have no idea if you're joking or being serious..
    BlueFox wrote: »
  • Jhayman
    edited August 2013
    Yes that's the way I remember it from school the water hose analogy which they also use for explaining how cable Internet works..
  • Ducati Guy
    edited August 2013
    Thanks guys that does help me understand it a little better.
    The garden hose analogy helps.
    I feel like the couch potato eating Cheetos while watching Stephen Hawkings explain worm holes, " yeah, I get it now as I grab for my 2nd bag of Cheetos".
    It's been 22 yrs since my last physics class I had to take in college. I'm a doc not an engineer, so learning these
    Concepts is like learning a foreign language, you don't really understand it until you use it.
    One more question, so how does amplifier watts relate to all this?
  • CoolJazz
    CoolJazz Posts: 572
    edited August 2013
    Something I don't thik was said exactly is this....
    A point of confusion is that...
    - Ohms is the unit of measure for DC resistance.
    - Ohms is also the unit of measure for AC inductance.
    So it's easy to start confused, stay confused and get even more confused as you try to understand. But a lot of explanation above goes on into the details. But (DC) resistance is only one simple thing. The inductance aspect has more to it. In speakers when you're given a number, that's what the driver is considered to be, but that doesn't reflect that the value will actually change as you change frequence.'
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
    edited August 2013
    Ducati Guy wrote: »
    The funny thing about all this is that it is rather low level introductory physics. Yet once you move to ask about amplifiers and watts, you begin to enter the domain of the designer/engineer and the lingo can become even more rarefied as if it isn't already. You're quite right though. If you are an electrician you have to have some working knowledge for how all the above "jargon" and elementary equations translate into what you have to do each day.
    As for me, I don't think that anything short of a primer by Nelson Pass, or John Curl with a LOT of dumbing down for the layman can really lead to anything more than a superficial understanding of what's involed--just like the general discussions in Stephen Hawking's series for us lay boys and girls--the real work, equations are so far beyond us and the analogies are so GROSS that we have only the "slightest" understanding of what these guys are actually doing since the most important part is High Level Math--pure numerical abstractions that translate badly into ordinary language, or not at all. I look at a circuit drawing and I have no idea what is going on there let alone of the schematics that my Tech repair guy deals with when he cracks open the case of one of my old amps? lol
    cnh
  • nguyendot
    edited August 2013
    And people don't think there are smart people on a lowly Polk speaker forum.....
    Main Surround -
  • bikezappa
    bikezappa Posts: 2,463
    edited August 2013
    Ducati
    The answers people have given are ok but I don't think you can get the complete answer in one or two paragraphs. It took me a semester at college to understand just the very basics of what you are asking. The key for me to determine if I understood the theory of basic EE was to do problems, lots of problems. You need to be good doing math problems with at least a good feeling doing basic algebra and hopefully calculus. Sorry if this isn't the answer to want but that's what it is.
    Peter
  • nhhiep
    nhhiep Posts: 877
    edited August 2013
    this thread reminds me of something I've always wondering about. how come most expensive, high end speakers are 4 ohms? while stuffs at BB or Fry's usually 8ohms?
    I was surprised that the LsiM is 8ohms, while Lsi is 4. so the ohms thing has little relation to sound quality right? if yes, then why did Polk make some 4 and 8 ohms speakers? why not just design all speakers with 8 ohms? so all AVRs can handle it, thus more sales too.
  • rpf65
    rpf65 Posts: 2,127
    edited August 2013
    nhhiep wrote: »
    Simple answer; power. Low impedance speakers will "force" the amp to put out higher current, in a sense, which equals more power.
    Problem is being able to match that low impedance, Really is a pretty complicated process.
  • Face
    Face Posts: 14,340
    edited August 2013
    Then there's the problem of phase angle...
  • Msabot1
    Msabot1 Posts: 2,098
    edited August 2013
    And don't forget your right triangle trig either!
  • Ducati Guy
    edited August 2013
    So using the garden hose analogy what do watts mean?
  • zingo
    zingo Posts: 11,258
    edited August 2013
    The watt is defined as one joule per second, measures the rate of energy conversion or transfer; that would be the liters per seconds for the garden hose.
  • bikezappa
    edited August 2013
    In practical terms, the ampere is a measure of the amount of electric charge passing a point in an electric circuit per unit time with 6.241
  • Ocezam
    Ocezam Posts: 52
    edited August 2013
    nguyendot wrote: »
    That's an good analogy.
    "The ear is not a microphone, the brain is not a tape recorder, and measurements are limited in describing subjective quality." Nelson Pass
    2 Channel:
    XDA-2, Modified Jolida JD502P (2 ea), Polk LSiM705
    Theater:
    Onkyo TX-NR3009 with 9 active channels, Emotiva XPA-5, MartinLogan Encore TF Center Channel, Polk M70 Mains, M40 Wides, M30 Heights, FXi A4 Surrounds, Custom built 18" sub, Mitsu 73" DLP
  • Msabot1
    edited August 2013
    Watts would be the force at the nozzle of the hose...current,the flow through the hose and resistance the diameter of the hose itself. The nozzle is actually a pot...a variable resistor P=IXE...power expressed in watts.
  • Ducati Guy
    edited August 2013
    Still pretty confused about watts?
    tonyb Posts: 33,072
    edited August 2013
    Some good analogies going on. From my perspective, unless your into building your own amps, the science of it all can get very confusing especially with different designs. However understanding the principles of what an amp does is essential, along with how that power effects speakers.
    Forget watts, people associate watts with gobs of power which isn't always the case. Peak to peak amperes, or current, in an amps spec's is a better judge of the power on hand but also isn't enough to gauge sound quality either. Too many variables in an amps build/design to tell just from a spec sheet.
    Now, some points of contention are receivers, some rated at 4 ohm capable. Most, not all, use that as a selling gimmick when in reality all that switch does is limit the current feed to a 4 ohm speaker to keep the smallish power supply in a receiver from overheating and going into protect mode. The last thing you want to do is limit the current flow to a speaker, yes ? We want as much as we can get, right ? That's why we always recommend a separate power amp for harder to drive speakers, current flow....and the more the better in most cases.
    Marketing gimmicks....that's for another thread, but understanding power, how to use it and why you need it is basic audio 101. Unfortunately the way specs read these days, it's a mine field of info that is just short of telling the whole truth so you learn to read between the lines. What's not listed in a spec is just as important as what is.....maybe more so. Personally, I don't put too much weight on specs but will use it as a guideline of sorts. I've heard too many pieces with fantastic specs that sounded like horse ****, while some with horse **** specs sounded better than they had a right to. So if your amp shopping, use specs as a guide, not a tell all piece of info of how it will sound.
    Glad to see some asking these questions, it's refreshing to see people wanting to learn instead of posting why they can't understand how they blew 2 tweeters at the same time....then blaming Polk speakers. :biggrin:
  • Msabot1
    edited August 2013
    My hat is off to you sir....here here!
