what is best method to clean tt stylus
pglbook
What do people use to clean a tt stylus?
Since I recently got back into vinyl, I have been researching how to clean records and a stylus.
I bought a Spin Clean record cleaning machine a few weeks ago and that seems to work fine but I still haven't learned what is the best way to clean a stylus. There is a lot of advice online and it is confusing.
Has anyone tried the Mr. Clean Magic Eraser method to clean a stylus? Does that really work?
There are a lot of positive reviews about that method online.
What would you recommend to clean a stylus?
I am using a Thorens TD 160 tt and Shure M97xE cartridge.
Thanks!!
Thanks!!
Post edited by pglbook on
http://www.mrclean.com/en_US/magic-eraser.do?utm_source=google&utm_medium=cpc&utm_term=magic%20eraser&utm_campaign=Mr.+Clean_Search_Desktop_Brand+Awareness&utm_content=sLoQimBKY_15185192589_e_magic%20eraser
http://www.elusivedisc.com/ONZOW-ZERODUST-STYLUS-CLEANER/productinfo/ZERODUST/
http://www.needledoctor.com/Last-5-Stylast
Listed from the order of preference of what I would use for a clean needle, moving onto more serious products for a not so clean needle. Been using the Magic Eraser for years, it works great for day to day dust removal.
bench grinder:cool:
Tom:
Thank you. That is very helpful. And I am glad to get confirmation that the Magic Eraser works well. I will definitely use it. I have a new stylus and I just want something to take off the daily dust that accumulates on the stylus from playing records. The little brush that came with the stylus really does not do too much.
How do you use the Magic Eraser? From what I have seen (there is a video online explaining this method), it seems like the best method is to cut a sliver of Magic Eraser and glue that to a piece of cardboard or a coin and then to place it on the platter (when it is not spinning off course) and, with the cue lever, merely raise and lower the stylus a few times into the Magic Eraser.
Is that how you use it? Or is there a better way to use it?
Thanks again for all of the great options and input. They are much appreciated.
Peter -
You are welcome pglbook. I didn't cut mine, I just use it as is and place the Magic Eraser straight up to the needle a couple of times, followed by a visual inspection. I haven't had any issues using it this way but if you have a shaky hand, you might want to do the arm drop.
Thanks again, Tom.
I use the Bald guy as well as a carbon fibre brush..
Which I stroke gently from back to front or bottom to top..
ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
Another Onzow Zerodust mention, and yes I have tried other methods.
I even went back to using my dust bug while playing records.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I've found a little sand paper will clean it right up
DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I use the MoFi cleaner, seems to work fine:
http://www.elusivedisc.com/MOBILE-FIDELITY-LP-9-STYLUS-CLEANER-WITH-BRUSH-05oz/productinfo/MFSL%2DLP9/Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
I cut the magic eraser thick enough to place it next to the platter and use the cueing arm to lower it on it.
Just a stylus brush here but I use it every side of every record I play and the stylus's stay clean.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Modelers detailing brush and at least 95percent alcohol...all you need.swipe stylus from rear.
+1, tried all the methods listed here and found this to result in best sound. I do dry brush after each play and wet clean every 3-4 sides.Speakers: SDA-1C (most all the goodies)
