what is best method to clean tt stylus
pglbook
pglbook Posts: 2,265
edited August 2013 in Electronics
What do people use to clean a tt stylus?
Since I recently got back into vinyl, I have been researching how to clean records and a stylus.
I bought a Spin Clean record cleaning machine a few weeks ago and that seems to work fine but I still haven't learned what is the best way to clean a stylus. There is a lot of advice online and it is confusing.
Has anyone tried the Mr. Clean Magic Eraser method to clean a stylus? Does that really work?
There are a lot of positive reviews about that method online.
What would you recommend to clean a stylus?
I am using a Thorens TD 160 tt and Shure M97xE cartridge.
Thanks!!
Post edited by pglbook on
    treitz3 Posts: 20,133
    edited August 2013
    http://www.mrclean.com/en_US/magic-eraser.do?utm_source=google&utm_medium=cpc&utm_term=magic%20eraser&utm_campaign=Mr.+Clean_Search_Desktop_Brand+Awareness&utm_content=sLoQimBKY_15185192589_e_magic%20eraser
    http://www.elusivedisc.com/ONZOW-ZERODUST-STYLUS-CLEANER/productinfo/ZERODUST/
    http://www.needledoctor.com/Last-5-Stylast
    Listed from the order of preference of what I would use for a clean needle, moving onto more serious products for a not so clean needle. Been using the Magic Eraser for years, it works great for day to day dust removal.
    pitdogg2 Posts: 27,371
    edited August 2013
    bench grinder:cool:
  • pglbook
    edited August 2013
    Tom:
    Thank you. That is very helpful. And I am glad to get confirmation that the Magic Eraser works well. I will definitely use it. I have a new stylus and I just want something to take off the daily dust that accumulates on the stylus from playing records. The little brush that came with the stylus really does not do too much.
    How do you use the Magic Eraser? From what I have seen (there is a video online explaining this method), it seems like the best method is to cut a sliver of Magic Eraser and glue that to a piece of cardboard or a coin and then to place it on the platter (when it is not spinning off course) and, with the cue lever, merely raise and lower the stylus a few times into the Magic Eraser.
    Is that how you use it? Or is there a better way to use it?
    Thanks again for all of the great options and input. They are much appreciated.
    Peter
    edited August 2013
    You are welcome pglbook. I didn't cut mine, I just use it as is and place the Magic Eraser straight up to the needle a couple of times, followed by a visual inspection. I haven't had any issues using it this way but if you have a shaky hand, you might want to do the arm drop.
  • pglbook
    edited August 2013
    Thanks again, Tom.
  • Jhayman
    Jhayman Posts: 1,548
    edited August 2013
    I use the Bald guy as well as a carbon fibre brush..
    Which I stroke gently from back to front or bottom to top..:lol:
    SCompRacer Posts: 9,128
    edited August 2013
    Another Onzow Zerodust mention, and yes I have tried other methods.
    I even went back to using my dust bug while playing records.
  • dkg999
    dkg999 Posts: 5,647
    edited August 2013
    I've found a little sand paper will clean it right up :smile:
    DKG999
  • nspindel
    nspindel Posts: 5,343
    edited August 2013
  • astar13656
    astar13656 Posts: 164
    edited August 2013
    I cut the magic eraser thick enough to place it next to the platter and use the cueing arm to lower it on it.
  • Fongolio
    Fongolio Posts: 3,516
    edited August 2013
    Just a stylus brush here but I use it every side of every record I play and the stylus's stay clean.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • Msabot1
    Msabot1 Posts: 2,098
    edited August 2013
    Modelers detailing brush and at least 95percent alcohol...all you need.swipe stylus from rear.
  • thsmith
    thsmith Posts: 6,082
    edited August 2013
    nspindel wrote: »
    +1, tried all the methods listed here and found this to result in best sound. I do dry brush after each play and wet clean every 3-4 sides.
