new to forum
hdmi65
hdmi65 Posts: 17
edited August 2013 in Electronics
Hi All,
New to forum and need some input to up grade my system. H/K 247 avr, 5.0 klipsch quintets , klipsch 12hg sub. looking at polk rtia 7for the front and a new center channel room size is 15/12.what do you think?
thanks mike
Post edited by hdmi65 on
  • chumlie
    chumlie Posts: 8,658
    edited August 2013
    My room is about the same size. Works well for me. But that HK will need to be put to pasture. Not enough power for the RTi's.
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    Thanks!
    looking at Denon 1913 would that work with the RTiS?
  • B Run
    B Run Posts: 1,888
    edited August 2013
    Honestly not really, i'd recommend something with more power and preouts. Whats your budget? I'm sure we can help ya out.
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    my budget around 5 or 6k what would you say for the Denon avr and could I use the quintet with some bigger front and a new center i like the 7,s but could go with less.
    Mike
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    hdmi65 wrote: »
    Mike
    also looking at denon avr x2000 and tsi500
  • chumlie
    edited August 2013
    Take a look at Pioneer SC series if your looking at AVR's. Some good deals to be had on the used market.
    nooshinjohn Posts: 25,907
    edited August 2013
    B Run wrote: »
    No doubt we can help... we excel at spending other people's money!:cheesygrin:
    Welcome to CP HDMI...
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    will do and Thanks!
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    Just starting out and want a good sound maybe not spend so much but want a nice system, If I can get by with less great room Is only 15/12 don;t want to over do It also.
    Thanks for the input! mike
  • zane77
    zane77 Posts: 1,696
    edited August 2013
    Welcome to the Club, this is THE place to let other people spend your money!
    Two Channel
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    Ok I see that open to anything great place here like the feed back I,am 64 yrs young but still have a good ear just would like a good set up been into Ham radio for a long time and $$$$$ spent on that , go to qrz.com and put my call in N4XT and you will see. but love my audio also.
    Thanks !
  • heartystatue
    heartystatue Posts: 329
    edited August 2013
    Welcome to CP. Get your read on and look at other members sig. There is everything from mild to crazy extreme here, There is more experience to answer questions on just about everthing audio. Good luck!
    HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
    2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC.
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    Yes and Thanks:rolleyes:
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    Thanks! lot of good stuff here
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited August 2013
    I have the Klipsch H/D #500 smalls w/ the 8'' pwrd sub and think they are great for H/T.i think Quintets are a model higher( might be wrong)since timbre matching isn't a problem then for sure upgrade to a better avr w/ pre/outs for an extermal amp for use futher down the road and you will hear this a million times. As an owner I do not recommend Yamaha rx-v665/667 they have power issuses if you like your tunes and or music on the louder spectrum w/o that external amp.
  • rpf65
    rpf65 Posts: 2,127
    edited August 2013
    Not really sure if you're looking to improve the sound, or just a different sound. I would suggest you look into a different AVR before deciding to change everything. Not sure what manufacturers you like, but there is sound improvement from the entry level models to the high end ones.
    It may be you're just lacking power, and adding a more robust AVR, possibly an amp, would solve the problem.
    Just saying I would advise looking at speakers after electronics.
    That being said, RTI A7's, CSI A6, FXI A6, and say a Pioneer SC 1522K could be had for around $3k, and be a nice system. Add some RTI A3's for the rears, and still well within your budget.
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    Thanks Zane77 I see that great forum.
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    Thanks,
    ok just order pioneer vsx 53 avr for a start last years unit but got it for half price what do you thnk.
    mike
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    avr H/K 247 klipsch quintets and sub. just order pioneer vsx53 avr half price and looking for speakers.
    thanks!
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    thanks Dskip,
    looking at speakers now just ordered Pioneer vsx 53 avr
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    thanks guys for the help! Just got the pioneer vsx 53 today
    mike
  • chumlie
    edited August 2013
    New receiver + long weekend = :biggrin: Congrats !!!
  • hdmi65
    hdmi65 Posts: 17
    edited August 2013
    thanks C well just starter 3-11 but that's ok pm you later:
    mike
