How low can you go? Noise floor in a silent room.
treitz3
treitz3 Posts: 20,360
edited August 2013 in 2 Channel Audio
Hello fellow Club Polk members and good morning to you all. Many of the discussions here and on other audio sites discuss high SPL levels and how good a system can sound at high volume levels. While this is a vaguely important part of audio playback, the other end of the spectrum is also an important part of audio playback as well. This thread is dedicated to exactly that.
We all have ambient noise within our house. A/C units and associated vents, refrigerators, dishwashers, computers, ballasts, electronic equipment, outdoor ambient noise, kids or spouses/girlfriends along with a plethora of other possibilities that can and will mask the minute subtleties and nuances our systems can offer. What I was wondering this morning was....how low can your room go? Even a completely silent, anechoic room will have a noise floor, unless one can remove the atmosphere of the Earth. Yes, air has noise and no one on Earth can have a zero Db listening room noise floor.
For those of you whom have never thought about this aspect of audio reproduction, give it a try. Cut off all of the known [and maybe not so known] noise sources in the room and the house. Well, at least the ones you have the power or ability to cut off. Make the room as silent as possible at the quietest time of the day or night. Then take an SPL meter and measure the room's ambient noise floor. For those who feel up to it, turn your system on with no music playing and remeasure.
How low can you go with or without your system?
While you are at it, go ahead and play a familiar track while the room is as quiet as you can possibly make it. Do you notice anything new?
  • Glen B
    Glen B Posts: 269
    edited August 2013
    I have measured a room noise level as low as 25dB A weighted/C weighted at 5:30AM. I woke up one morning and the house was so quiet, I broke out the SPL meter to check the noise level.
    edited August 2013
    Nice! Great start to this thread. Thank you, sir.
  • Speedskater
    Speedskater Posts: 495
    edited August 2013
    So we have several questions here:
    a] How low can a person with excellent hearing go in a soundproof test lab, after an acclamation time period.
    b] How quite can a purpose built listening room be.
    c] How quite can a typical residential room be.
    d] How quite can a recording studio or concert hall be with musicians in it.
    e] How low can a typical SPL meter measure. (most don't do well at low SPL levels)
    edited August 2013
    Hello, Speedskater. All of these are excellent questions. Hopefully we can address these one by one as this thread progresses. My hat is off to you, sir!
    Geez, it has been a while for this thread. 23dB just now.
    What say you?
    billbillw Posts: 8,285
    edited September 1
    I need to have my ceiling fan on full blast this time of year. I'd venture it is never lower than 50dB. Winter, on low speed, with the heat pump off, it is definitely quieter, but I'm not sure how much lower since the Radio Shack sound meter I own only goes down to 50dB. How did you measure 23dB? Do you have one of these?
    https://www.grainger.com/product/EXTECH-Sound-Level-Meter-20-dB-817MC2
  • woofiepaws
    woofiepaws Posts: 226
    Buying a new meter....
    Thinking about this today, there are apparently some fairly affordable USB microphones that have self noise below 20dB, so in combination with a fanless computer or phone, you might be able to get fairly accurate measurements without spending $5K 😅
  • spongebobsquarepants
    This thread got me to look at the specs for my Ohr-1 meter. It only measures down to 32dB, and the lowest I've seen in the listening room is 34dB.
  • ptrooper
    ptrooper Posts: 739
    edited September 6
    If you'r getting a 23-24 db noise floor , You gotta be happy with that,i am .......my room also hits 38 db or more on a noisy day.
    VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable, <3 ,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
