LsiM Crossover Picture
zingo
Can anyone post a picture of a LsiM crossover? I can't seem to find one online, and I'm doing research for a project based on current Polk crossover components.
Thanks for the help!
They are in the last MD polkfest pictures found on my website- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Did you get a close look at them? Do you know what brand film caps they used in the HF circuit?
Polk audio branded poly caps- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I would assume bennic or the like made them- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
