what are good inner and outer sleeves for vinyl collection?
pglbook
pglbook Posts: 2,261
edited August 2013 in Electronics
I am getting back into vinyl and am starting to put together an album collection again and would like to protect them as best as I can.
What is recommended for outer sleeves (plastic) to protect the album cover?
What is recommended for inner sleeves (paper? plastic?) to protect vinyl?
I have been doing some online research but thought I'd check with Polkie vinyl enthusiasts because this site has always given me the most knowledge and the best advice.
Thanks.
Post edited by pglbook on
  • agfrost
    agfrost Posts: 2,469
    edited August 2013
    The Mofi inner sleeves are very nice, and used by many around here. I'm actually going to tune in to your thread to see what people like for outer sleeves, as I'm less than crazy about the ones I've been using.
    Jay
    gudnoyez Posts: 8,161
    edited August 2013
    I use the pvc inner line sleeves the anti static ones, and the pvc outter ones to protect the album covers. You can find these on line amazon has a good selection. I remember the real record stores would give you a outter sleeve every time you would buy an LP from them. Over in Germany you could listen to an album before you bought it sit at a round table with headphones order up a beer. When you bought an album ( they were not shrink wrapped over there) you would get a complimentary inner and outter sleeve, the store over there was called Musikuss.
    SCompRacer Posts: 9,112
    edited August 2013
    Welcome back.:wink:
    Like Jay, MoFi is a preferred favorite for record sleeves.
    Jacket sleeve, I like no less than 3 mil minimum thickness polyethylene. Bags Unlimited is a good source. They sell both type of poly sleeves, polyethylene and polypropylene.
    The best archive type are Japanese resealable sleeves.
    Some reading about poly sleeves.
    http://www.dtmagazine.com/polyvspoly.html
    Jay, school in yet? I got some rekkids for you. Rob said he did too.....
  • agfrost
    edited August 2013
    SCompRacer wrote: »
    I is. Tried to send you a PM, but your box is full. I'd make fun of you for that fact, but mine's bursting as well.
    Jay
    edited August 2013
    Fixed....guess I was talkative...lol
  • PolkieMan
    PolkieMan Posts: 2,446
    edited August 2013
  • Obsession18
    Obsession18 Posts: 191
    edited August 2013
    These inner sleeves have served me well, $36 for 100:
    https://www.bagsunlimited.com/p-3155-12-polylined-sleeves.aspx
    I haven't done the outer thing yet.
    2-Channel System
    Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
  • Emlyn
    Emlyn Posts: 4,710
    edited August 2013
    Rick88 wrote: »
    There are several different options here:
    http://www.sleevecityusa.com/default.asp
    I use theirs. For the outer I use the 5 mil sleeves which are nice and clear, and for the inner I use their Diskkeeper audiophile sleeves. Their outer sleeves are sized so they can take a double gatefold LP fairly easily without splitting the seam on the sleeve. Their inner sleeves aren't really less expensive than the Mobile Fidelity type, but they are a bit thicker and don't tend to fold corners as easily going into a jacket. Actually, since I started using the outer sleeves I just put the inner sleeve behind the album cover in the outer sleeve rather than reinserting it in the cover.
    http://www.sleevecityusa.com/diskeeper-audiophile-inner-sleeve-50-pack-p/312nrps.htm
    http://www.sleevecityusa.com/ultimate-outer-5-0-record-sleeve-p/9380.htm
    They are also available to be shipped by Amazon, but the prices are a bit higher than ordering directly from Sleevecity. I usually order from Amazon because of free shipping from there. Comes out a bit cheaper that way.
