Looking for a Digital Coaxial cable bewtwwen CDP ---> DAC (MIT AVT line?)
acmf74
Hi,
I'm looking for a new coaxial digital cable and my budget is around $100.
Has anyone have any experience with the MIT AVT line? I'm also open to suggestions.
Thanks,
Thanks,
Post edited by acmf74 on
What length do you need?Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
What do you have now ?
Lots of guys use the Blackcat Veloce.HT SYSTEM-
lsi 9's -
I need a cable between 1.5M - 2M in length.
I currently don't have a cable and looking for suggestions.
Thanks, -
http://www.accessories4less.com/make-a-store/item/IXOSXHD608200/IXOS-Xhd608-Digital-Coax-Audio-Cable-Silver-Plated-2m-6.5ft/1.html
Won 'digital audio cable of the year award' in What Hi Fi Sound and Vision 2 years in a row.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
At 1 or 2 meters, any cable of MonoPrice quality or up will work. Once you get past about ten meters then cable quality starts to get more serious.
EndersShadow wrote: »LOVING mine!
Thanks again Phil!
LOL....you fanboy you. Glad your diggin' it. Phil gave you a helluva price on that puppy to. You best buy the guy a beer or 10 if you ever run into him.HT SYSTEM-
lsi 9's -
Thanks again Phil!
You're quite welcome...that is one hell of a cable! -
I purchased the AES version of this for around $100. I'm not sure if it was a mistake or not, but there were two in the package. It sounds pretty good on my spare system. Once I get some time on it I will compare it to my $750 Zytron Python digital.
http://bryston.com/products/other/digital_RCA.htmlLumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
It's not being a fanboy if it just sounds stinking GOOD!
And it does. Opened up my soundstage."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
i have one from this fella, and I like what it did over my cheap TOSLINK cable. and seems to be very well made.
http://www.groverhuffman.com/interconnectsPolk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Not a bad price either ^^^. Plus he has the length you require, the Blackcat only comes in one length.HT SYSTEM-
lsi 9's -
just a word of.. well, knowledge. Grover is a bit on his own schedule. It might take a little longer than what is normal to get your cable. IIRC, it was something like 3 weeks+ between ordering and my doorstep.
I choose him based on another member's review of both the digital cable and IC's. At the time I was using a Tributaries TOSLINK, and just was experimenting with finding out of a digital cable would matter.
To my ears, the stage opened up, I lost some edginess in the vocals, and everything just seemed a bit more anchored. And quieter... meaning I think I had some sort of noise from the TOSLINK. It may sound weird, but I can't tell you what it was, just that I noticed it was gone.
I would like to try a set of IC's from him, but there is a pair of Infinity RSb's in need of inductors first.Polk Lsi9
Keces DA-131 mk.II
